Windage tray
#2278270
03/29/17 12:24 PM
03/29/17 12:24 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
Building a 572 Hemi. Milodon says their tray fits up to 1/2" stroke or 4.25". This thing is obviously 4.5". Whose tray will fit this thing? Thanks.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
Re: Windage tray
[Re: sixpackbee]
#2278277
03/29/17 12:38 PM
03/29/17 12:38 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I used the Milodon stroke tray on my 572 w/ 2.2 BBC rods. Don't think it'll clear if you still have the big mopar rod journals.
Re: Windage tray
[Re: sixpackbee]
#2278284
03/29/17 12:54 PM
03/29/17 12:54 PM
Posts: 31,078 Oregon
AndyF
Building a 572 Hemi. Milodon says their tray fits up to 1/2" stroke or 4.25". This thing is obviously 4.5". Whose tray will fit this thing? Thanks. you'll just have to buy a few of them and try them. The Milodon one might fit but depends on your pickup. Jegs has one which might work as does 440Source. Just buy all three and see which one works the best. Or more likely, find out which one you'll be able to modify with the least amount of work.
Re: Windage tray
[Re: AndyF]
#2278287
03/29/17 12:57 PM
03/29/17 12:57 PM
sixpackbee
Western New York
No internal pick up. Probably will end up modifying something I suppose.
Re: Windage tray
[Re: sixpackbee]
#2278293
03/29/17 01:09 PM
03/29/17 01:09 PM
an8sec70cuda
No internal pick up. Probably will end up modifying something I suppose. What size rods are you using?
Re: Windage tray
[Re: an8sec70cuda]
#2278299
03/29/17 01:29 PM
03/29/17 01:29 PM
sixpackbee
Western New York
RB big end, steel, Oliver 7.100"
Re: Windage tray
[Re: sixpackbee]
#2278311
03/29/17 02:12 PM
03/29/17 02:12 PM
an8sec70cuda
Yep, you'll be trimming something to fit most likely.
Re: Windage tray, 1/4 inch oil pan spacer solution
[Re: sixpackbee]
#2278373
03/29/17 03:49 PM
03/29/17 03:49 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
I tried sending you a PM but that wouldn't work ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif) I had a batch of 1/4 inch thick billet aluminum oil pan spacers made several years back to use on RB and Hemi motors with 4.5 inch stroke crank. Using these allows the use of the stock Mopar windage tray between the bottom of the spacer and the oil pan with most steel rods and 4.5 inch standard Mopar rod journals PM me if you want one, $75.00 plus the actual shipping ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
