Re: High output Toyota Alternator [Re: Chassisman] #2278204
03/29/17 09:44 AM
03/29/17 09:44 AM
Parts unknown
590 Challenger Offline
Parts unknown
Originally Posted By Chassisman
www.alternatorparts.com has a ton of big amperage units for lots of different applications...up to 350 amps !!!...nuts
Randy does good for a one man shop out of his garage, I would have to say he has to be the most creative guys out there.
As far as stepping alternators up to higher amperage from a small alternator you always have to lose something, heat issues, less charge at low RPM. OE makes as small as they think they should to keep things reliable and with the charge being at the RPM's they want. If they could keep making them smaller, they would keep shrinking them until they look like a micro chip by now. You can step most alternators up 35-40% without losing a whole lot of low end power. I guess it depends on what you are using it for. For drag cars you can step them up a lot and keep it small, high RPM's and short run time, perfect.
I sell parts to starter and alternator rebuilders for a living. For the CS130D (normally 105 amp) I think I have a couple hundred 200 amp stators on the shelf to step them up. I talk customers out of buying them. They don't work worth a darn. Kids think they want a 200 amp alternator to run their stereos, fact is these put out way less power idling and driving around town then their OE alternator. They make power but the RPM's must be screaming. Larger alternators step up power much better
Re: High output Toyota Alternator [Re: 590 Challenger] #2278243
03/29/17 11:32 AM
03/29/17 11:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Is that CS130D a small case denso.. and is it a external
regulator
wave
Re: High output Toyota Alternator [Re: 590 Challenger] #2278344
03/29/17 02:50 PM
03/29/17 02:50 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Good to know...I have a Denso on a DOTE bracket. With my fans and all acc running the voltage meter drops to around 12volts...I watch it like a hawk. I got the alt off a Honda CRX years ago.Not even sure of the amperage. But it works. If I need to upgrade I'll contact you.
Re: High output Toyota Alternator [Re: Scamp408] #2278346
03/29/17 03:00 PM
03/29/17 03:00 PM
Parts unknown
Parts unknown
CS130D is a Delco unit, it's pretty good. I think I read you have a Denso on yours now Mr. P? I would just up that one to your needs, less weight, less rotating mass, everything already lines up and you don't street drive it
Re: High output Toyota Alternator [Re: Scamp408] #2278391
03/29/17 04:15 PM
03/29/17 04:15 PM
MN
W
Willie68coronet Offline
W
MN
How are these 120 amp externally regulated Denso's?
91 dodge w350 alt
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: High output Toyota Alternator [Re: 590 Challenger] #2278417
03/29/17 05:25 PM
03/29/17 05:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I will be using this on my Rampage.. its street driven
with injection... the part that Willie shows below is
pretty much what I think I need but with a single pulley..
assuming this is the same size as the 70a
thanks
wave
Re: High output Toyota Alternator [Re: Willie68coronet] #2278539
03/29/17 10:03 PM
03/29/17 10:03 PM
Parts unknown
Parts unknown
91 dodge w350 alt
They are pretty good work horses, just a little large. They make self excited regulators to make them a 1 wire too
Re: High output Toyota Alternator [Re: MR_P_BODY] #2278540
03/29/17 10:04 PM
03/29/17 10:04 PM
Parts unknown
Parts unknown
thanks
wave
It's probably about 25% larger than the one you have
Re: High output Toyota Alternator [Re: 590 Challenger] #2278565
03/29/17 10:49 PM
03/29/17 10:49 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
how do you identify the denso unit? only numbers I see are 665 D2.
Re: High output Toyota Alternator [Re: 590 Challenger] #2278650
03/30/17 12:29 AM
03/30/17 12:29 AM
MN
W
W
MN
91 dodge w350 alt
Cool, thanks. So it puts out decent amps at idle? More than the toyota self regulated one or the same? I understand it depends on idle rpm and whatnot.
Re: High output Toyota Alternator [Re: Scamp408] #2278812
03/30/17 12:13 PM
03/30/17 12:13 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Thanks to all. After thinking about it I am going to use the 120 denso. As of now it will have to wait since I have to redo my brackets but another project on my list. I have a nice denso Mopar 90 amp and a denso 50 amp mini I will post forsale soon.
