Leaf Spring front bushing size 69 Charger RT 440 #2277450
03/28/17 12:08 AM
03/28/17 12:08 AM
NC
Sixt8Chrgr Offline OP
NC
Is the OEM front bushing for the OEM leaf springs 1.5" OD or 2" OD ?
Re: Leaf Spring front bushing size 69 Charger RT 440 [Re: Sixt8Chrgr] #2277580
03/28/17 10:06 AM
03/28/17 10:06 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
It depends on which spring you have. The ones for the HD 6-7 leaf springs have the smaller bushing. All the rest have the big 2" ones.
Re: Leaf Spring front bushing size 69 Charger RT 440 [Re: Sixt8Chrgr] #2277590
03/28/17 10:13 AM
03/28/17 10:13 AM
NC
NC
My car is a RT 440 with original springs. So the 1.5" bushings?
Re: Leaf Spring front bushing size 69 Charger RT 440 [Re: Sixt8Chrgr] #2277596
03/28/17 10:27 AM
03/28/17 10:27 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Most likely. Go out and measure them.
Otherwise count how many leafs you have per side.
If you have 5 leafs on both sides then they are 2"
If you have 7 on the passenger side and 6 on the other side you have 1.5"
Either way you need to use your eyeballs for this one
