5.7 hemi into 07 Dakota #2264448
03/06/17 06:52 PM
03/06/17 06:52 PM
Kalispell Mt.
HotRodDave Online content OP
HotRodDave  Online Content OP
Kalispell Mt.
So are there any motor mounts out there or am I gonna have to make some for my 4x4?
Also for the throttle body what is everyone doing? My 4.7 has a cable but the 5.7 is drive by wire. Is there a big manual throttle body that will work with the 4.7 computer or do I got to use the 4.7 TB or what? If I go to switching computers then I got to wory about VIN, security and miles programming...
Everyone says its real easy but having a hard time finding anyone that followed this through to completion.
Re: 5.7 hemi into 07 Dakota [Re: HotRodDave] #2264492
03/06/17 08:00 PM
03/06/17 08:00 PM
Wichita Kansas
6PacCuda Offline
6PacCuda  Offline
Wichita Kansas
I would think you could get all the parts you need from a Durango or Jeep Commander. I know they both came with Hemi's. The computers can be programmed for mileage.
Re: 5.7 hemi into 07 Dakota [Re: HotRodDave] #2264514
03/06/17 08:57 PM
03/06/17 08:57 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Motor mounts will need to be made. You maybe able to convert your existing ones to fit the hemi. Not sure if the Dak 4X4 is steel or aluminum.
Mopar has a big TB. expensive @ 500.
Your computer can be re-tuned to run the hemi if you don't use the drive by wire.
Not to sure what year they switch from a 32 reluctor wheel to a 64 on the 4.7. Something to think about.
Matt
Re: 5.7 hemi into 07 Dakota [Re: HotRodDave] #2275114
03/24/17 12:28 AM
03/24/17 12:28 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Aren't the Dakotas the same as the Durangos under the hood and same frame?
Re: 5.7 hemi into 07 Dakota [Re: HotRodDave] #2275227
03/24/17 04:08 AM
03/24/17 04:08 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
Schumacher Creative Services makes conversion Gen 3 hemi motor mounts for 1997-2004 Dakotas. Not sure they will work for a 2007, but probably worth looking into.
Wailin
http://engine-swaps.com/Pages/ProductsYear/9704Dak.html#head6
Re: 5.7 hemi into 07 Dakota [Re: cudaman1969] #2276192
03/25/17 10:01 PM
03/25/17 10:01 PM
IN
ahy Offline
ahy  Offline
IN
1'st generation Durangos were based on the Dakota. They never had the Hemi. 2'nd generation Durango's (~2006) did have the Hemi and were different underneath I believe. Still worth checking as 2'nd generation Durangos also had the 4.7.
Re: 5.7 hemi into 07 Dakota [Re: HotRodDave] #2276223
03/25/17 11:07 PM
03/25/17 11:07 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I know the 5.7 will swap where a 4.7 was and the computer can be reused (check he number of connectors,3 or 4 as to compatability) I have a 2004 Durango 5.7 Hemi it is a TIGHT fit in the engine compartment!I thought about headers vs the stock log manifolds,but I don't think they will fit at all.I pulled the blown motor and I'm putting in a new long block.Most time consuming engine R&R I have ever done,and I have done many.Everything is in the way of something else.It is an AWD chassis though,which ads to the mix.I would hope yours is 2wd!
RT
Re: 5.7 hemi into 07 Dakota [Re: HotRodDave] #2276671
03/26/17 06:56 PM
03/26/17 06:56 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Also try DakotaDurango.com under the engine specific thread. "5.7 Hemi "
Re: 5.7 hemi into 07 Dakota [Re: HotRodDave] #2276822
03/26/17 11:14 PM
03/26/17 11:14 PM
Kalispell Mt.
Kalispell Mt.
its a 4wd and the front diff bolts on different on the 04 hemi durango sitting in here.
Re: 5.7 hemi into 07 Dakota [Re: HotRodDave] #2276931
03/27/17 01:24 AM
03/27/17 01:24 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Dave,How is the diff...different on the '07 vs the '04?
Re: 5.7 hemi into 07 Dakota [Re: HotRodDave] #2277173
03/27/17 02:43 PM
03/27/17 02:43 PM
Kalispell Mt.
Kalispell Mt.
I am not looking right now but one the bracket bolts to the top of the diff front to back and the other bolts to the top of the diff side to side. My interchange says 01 to 11 dakota front diff interchange and only 01-03 durango will go in the 01 to 11 dakota. For some reason when they changed the durango body in 04 they decided they should change the way the front diff mounts.
