Modern telescoping steering column? #2276039
03/25/17 03:52 PM
03/25/17 03:52 PM
ON, Canada
migsieca Offline OP
migsieca  Offline OP
ON, Canada
Has anyone had success installing a modern Chrysler telescoping steering column into (for instance) a 72 Satellite?
I would like the flexibility in order to increase comfort over long drives etc. Nothing worse than not being able to adjust the steering wheel to a comfortable height/depth.
Re: Modern telescoping steering column? [Re: migsieca] #2276168
03/25/17 09:04 PM
03/25/17 09:04 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I installed a 78 Wagoneer tilt steering column into a 72 Chevelle. Bolted in, minor wiring change
The Saginaw columns are modular and very swappable. If 72 Sattelite had tilt as an option, bid take the chance that tele would bolt up, just need the adapter harnesses.
Angry white pureblood male
Re: Modern telescoping steering column? [Re: ruderunner] #2276375
03/26/17 10:41 AM
03/26/17 10:41 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Tilt and tele? work
If I was looking for just tilt, I would be looking at the later B's like '75-'79 Cordoba.
Tilt and tele I think only came in C bodies. I doubt one of those would simply bolt in, but I'd be looking at later C's.
If it doesn't have to be factory, there are companies out there like IDIDIT that sell universal tilt and tele columns.
Flaming River has a power tele column with memory...how much do you want to spend?
(note: I've never dealt with either company, just pointing them out)
popcorn
John
Re: Modern telescoping steering column? [Re: migsieca] #2276465
03/26/17 01:34 PM
03/26/17 01:34 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
I was looking at a modern Chargers steering knuckle the other day.
The rag joint looked awful familiar.
Red
Re: Modern telescoping steering column? [Re: migsieca] #2276575
03/26/17 04:12 PM
03/26/17 04:12 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I wouldn't try a column newer than say mid 80's. That's when Saginaw started with column mounted wiper switch, column mounted dimmer and maybe a couple other things.
I'm pointing out the Saginaw columns because that's what Mopar used for tilt column and the tilt tele.
Finding a late b tilt column should be easy and a good start, might even bolt in. Grabbing a tele column from a caddy or newyorker put em on a bench and see if you can build one.
There's a reason the aftermarket columns are based on the Saginaw units.
