Re: adjusting power steering gear
[Re: mcat4321]
#2276041
03/25/17 03:54 PM
03/25/17 03:54 PM
RapidRobert
when running is it sloppy? they have play in the wheel when not running & that might be a factor in the play you feel down below. On adjusting I would jack up the front wheels off the ground with them centered & idle it & see if it wants to pull. for adjusting it on that part you lightly tap the top piece forward or backward with it loosened a bit but still snug (there is more to it than that) but I would consult the FSM.
[Re: mcat4321]
#2276043
03/25/17 03:56 PM
03/25/17 03:56 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I would suggest you start with the procedure in the FSM.
[Re: RapidRobert]
#2276282
03/26/17 01:16 AM
03/26/17 01:16 AM
Posts: 18,160 Mass
DAYCLONA
Mass
when running is it sloppy? they have play in the wheel when not running & that might be a factor in the play you feel down below. On adjusting I would jack up the front wheels off the ground with them centered & idle it & see if it wants to pull. for adjusting it on that part you lightly tap the top piece forward or backward with it loosened a bit but still snug (there is more to it than that) but I would consult the FSM. ...
