What is your highest horsepower, using electronic ignition?
#2275548
03/24/17 07:52 PM
03/24/17 07:52 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
What horsepower are you guys getting with the stock Chrysler ignition? List whatever ignition module you are using, and what era box. Such as,I heard, the old Gold Race boxes are excellent. Orange not so good. But what years were iffy? What compression ratio's? Revenatator customers, what are your highest horsepower numbers for your combo's? Whose electronic distributor and coil are you using? I think this will be a very valuable list for people building and gathering parts, or looking to upgrade parts..Just electronic, no MSD or anything NOT using the Mopar type Electronics.. Thanks
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: What is your highest horsepower, using electronic ignition?
[Re: sunroofgtx]
#2275834
03/25/17 09:33 AM
03/25/17 09:33 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I ran an Orange box for a long time. The only problem I had with them was they would leave me stranded. I put a no name parts store brand box in and never looked back, ran into the 11.30s on a nitrous 360 before switching to MSD ages ago.
68 Barracuda Formula S 340
[Re: sunroofgtx]
#2275891
03/25/17 11:51 AM
03/25/17 11:51 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I had a friend that ran an orange box with an MSD rpm activated switch module that would bypass the ballast resistor above 3000rpm. That car was just under 3000 lbs, went 9.30 best.
[Re: sunroofgtx]
#2276012
03/25/17 03:04 PM
03/25/17 03:04 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Only engines I have that are still running stock type ignitions are less than 400 HP. That would be the truck 360 that was in the RamCharger, stock 318 in the Coronet 500, and the stock 73 Jensen Interceptor 440.
[Re: TRENDZ]
#2276048
03/25/17 04:09 PM
03/25/17 04:09 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
I had a friend that ran an orange box with an MSD rpm activated switch module that would bypass the ballast resistor above 3000rpm. That car was just under 3000 lbs, went 9.30 best. Cute. I like it! You could do that to use the chrome or gold box on the street using the appropriate resistor. Paint the box black and hide the switch/relay and it could look dead stock.
[Re: sunroofgtx]
#2276205
03/25/17 10:36 PM
03/25/17 10:36 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
The best my car ever ran was with the old Direct Connection 404BC multispark unit then one day it was warming up in the driveway and just shut off. I wish I could get that box rebuilt but when I called MSD they said it was "unserviceable" Had a chrome box for a while then it melted and died. Couple of orange orange boxes,one good one bad. Put an NOS MSD 6AL from the early eighties and still going strong with my Firecore distributor. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: sunroofgtx]
#2277988
03/28/17 09:03 PM
03/28/17 09:03 PM
sunroofgtx
Cleveland
I was hoping someone had an over 500 hp car using it..
[Re: sunroofgtx]
#2278082
03/28/17 11:58 PM
03/28/17 11:58 PM
Posts: 7,506 Az
Crizila
Az
D.U.I. ignition ( including wires). 650+ HP supercharged small block. NGK's at .028". Static CR somewhere near 16 - 17:1 at boost. " Lightem if ya gottem".
Fastest 300
