What is this transmission? #2275420
03/24/17 03:15 PM
03/24/17 03:15 PM
God's Country Maryland
GODSCOUNTRY340 Offline OP
Doesn't look anything like a 727 or 904. Body bolts to the bell.
Re: What is this transmission? [Re: GODSCOUNTRY340] #2275424
03/24/17 03:27 PM
03/24/17 03:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's an iron Powerflite 2-speed from the fifties.
Re: What is this transmission? [Re: GODSCOUNTRY340] #2275444
03/24/17 04:08 PM
03/24/17 04:08 PM
Colorado springs, CO
Arominus Offline
Arominus  Offline
Yup, looks like am air cooled powerflight 2 speed, you'll need an adapter plate to put anything else on that motor. You will use the same adapter that the chrysler 331/354/392 hemis use for whatever transmission you want to put on it.
If you decide to use the powerflight, its got ratios of 1.72 and 1.00. You can add take offs to run lines up to a trans cooler (i would) the torque converter has fins on it that help cool it as well. Thats why the bellhousing has those mesh covers over the openings.
1956 315 hemi? a 57 325 hemi would likely have a torqueflight on it.
1957 Desoto Firesweep 2dr
392/A518 builds in progress.
Re: What is this transmission? [Re: Arominus] #2275452
03/24/17 04:23 PM
03/24/17 04:23 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Exactly what was in my 56 D500.
Re: What is this transmission? [Re: GODSCOUNTRY340] #2275484
03/24/17 06:01 PM
03/24/17 06:01 PM
I'm in the process of taking this apart right now, how the heck does the torque convertor un-bolt? I have the trans separated from the engine but don't see any kind of a flex plate or flywheel for un-bolting it from the crank. Does it have to come out with the crankshaft? I'm not going to use the trans, is there any market for them?
The engine is a '55 270 Hemi. I plan on it ending up in my '54 Flat fender Powerwagon.
Re: What is this transmission? [Re: GODSCOUNTRY340] #2275517
03/24/17 06:54 PM
03/24/17 06:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The converter has eight studs that go through unthreaded holes in the crank flange with nuts on the front of the flange.
Re: What is this transmission? [Re: John_Kunkel] #2275520
03/24/17 06:58 PM
03/24/17 06:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Just to be clear, there is no flexplate, just the studs poking out the nose of the converter thru the crank.
You can kinda see it in the pic at Allpar
http://www.allpar.com/mopar/powerflite.html
Don't be the exception.
Re: What is this transmission? [Re: GODSCOUNTRY340] #2275540
03/24/17 07:38 PM
03/24/17 07:38 PM
Arominus Offline
Arominus  Offline
That reminds me, you'll need a hemi flexplate if you run a newer 727 on it.
Re: What is this transmission? [Re: Arominus] #2275558
03/24/17 08:13 PM
03/24/17 08:13 PM
Okay, I see them. Looks like there's not much room to get the nuts off, how hard are they to remove?
Re: What is this transmission? [Re: GODSCOUNTRY340] #2275566
03/24/17 08:25 PM
03/24/17 08:25 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Not very fun to remove. Take off trans and bell house.
Re: What is this transmission? [Re: GODSCOUNTRY340] #2275567
03/24/17 08:27 PM
03/24/17 08:27 PM
Thanks everyone. Looks like I know what I'll be doing tomorrow.
Re: What is this transmission? [Re: GODSCOUNTRY340] #2275583
03/24/17 09:01 PM
03/24/17 09:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Exercising your vocabulary of curse words no doubt.
Re: What is this transmission? [Re: GODSCOUNTRY340] #2275800
03/25/17 04:07 AM
03/25/17 04:07 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Funny!
Re: What is this transmission? [Re: Supercuda] #2276790
03/26/17 10:24 PM
03/26/17 10:24 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I can tell you from experience his does not need exercising... biggrin
...FAFO...
Re: What is this transmission? [Re: GODSCOUNTRY340] #2276976
03/27/17 05:21 AM
03/27/17 05:21 AM
It helps if you have a flywheel wrench designed for those converter, long skinny open end wrench up
If you reuse that type converter don't forget to reuse the star lock washers up
Is your Power Wagon a stick shift? If so the six cylinder flywheel and starter will work on those early V8 with the correct truck bell housing, you may need to machine the crankshaft for a pilot bushing though scope
I put a 1957 392 New Yorker in my old 1955 Dodge D500 car hauler after the flathead six broke down the last time on the road, that engine swap made that a real truck boogie up
Re: What is this transmission? [Re: Cab_Burge] #2277177
03/27/17 02:56 PM
03/27/17 02:56 PM
Luck finally came my way, once I broke the nuts loose they all came out with my fingers and believe it or not no curse words were flying around my garage. Even I can't believe that one. The Powerwagon is a stick but I'm going to attempt to adapt it to an '87 Powerwagon auto trans. I've been told the adapters for the 331 & 354 Hemi will fit this 270 Hemi. Skicker, I learned all my bad language from you! Ha, Ha.
