1970 440 HP Convertor Weights
#2274468
03/22/17 09:28 PM
03/22/17 09:28 PM
Posts: 10,726 North Dakota
6PakBee
North Dakota
After nearly three hours of searching I cannot find anything definitive about the torque converter weights for a 1970 440 HP. I can find tons of information on cast crank weights but not the forged crank heavy rod 440's. Does the converter for a 440 HP have weights? If so how much weight? Is there a weight kit for this (can't find an application in Mopar Performance). Does it straddle the drain plug like the typical converter weight?
Re: 1970 440 HP Convertor Weights
[Re: 6PakBee]
#2274531
03/22/17 11:02 PM
03/22/17 11:02 PM
Posts: 71 Sudbury, ontario canada
750-h2
First thing to do is make sure your engine is externally balanced by checking if it has the balance weight on the front of the harmonic balancer. If it does according to the Mopar Performance catalogue you will need to buy a neutral balance torque converter and then buy weight kit part # P4120241. This kit is for externally balanced cast cranks as well as the externally balanced 1970 & 1971 440 six pack engines and all other 440's with heavy rods[all have forged cranks]. Kit comes with a template and instructions.
[Re: 750-h2]
#2274602
03/23/17 12:56 AM
03/23/17 12:56 AM
6PakBee
North Dakota
.....buy weight kit part # P4120241. This kit is for externally balanced cast cranks as well as the externally balanced 1970 & 1971 440 six pack engines and all other 440's with heavy rods[all have forged cranks]. Kit comes with a template and instructions. I saw that kit during my search and every time it popped up the application was listed as: Torque Converter Balance Weight & Positioning Template Kit Fits Most 1971-'79 383/440 (with cast crank) Fits 1971-'92 360 Fits 1971-'76 340 (with cast crank) There is no mention of the '70 heavy rod steel crank 440. Do you have a copy of the instructions or some other documentation that indicates this kit has this coverage? Appreciate the help.
[Re: 451Mopar]
#2274646
03/23/17 05:31 AM
03/23/17 05:31 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I had a '70 440 HP (I think that is the "F" code?) in the '69 convertible when I bought it, but it was a 4-speed. I don't recall any balance stuff on the flywheel? I think the flywheel and clutch assembly is still in a box around here. I sold the engine/trans to a guy doing a superbird clone. The 505" stroked 440 in my car is the '69 "E" code engine.
The flywheel in 70 has no weights added. It has material that is removed to achieve the balance.
[Re: fastmark]
#2274694
03/23/17 10:52 AM
03/23/17 10:52 AM
6PakBee
North Dakota
You can buy a flex plate with the proper weights on it to balance the motor and then use a neutral balance converter. That sounded like a real plan until I checked. Anyone I could find did not have an application for a forged crank externally balanced engine. Cast crank yes, forged no. Maybe I'll just have to start calling.
[Re: 6PakBee]
#2274710
03/23/17 11:35 AM
03/23/17 11:35 AM
Posts: 601 Mass
charge70
Mass
Bee,I have the drive train out of my 70 R/T at home.It's a 440 u-code car that still has the original motor and trans. I can take a pic of the face of the converter if you want me to.Let me know. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#2274725
03/23/17 12:10 PM
03/23/17 12:10 PM
6PakBee
North Dakota
Bee,I have the drive train out of my 70 R/T at home.It's a 440 u-code car that still has the original motor and trans. I can take a pic of the face of the converter if you want me to.Let me know. John. John, that would be great. I've sent you a PM.
[Re: jlatessa]
#2274732
03/23/17 12:20 PM
03/23/17 12:20 PM
6PakBee
North Dakota
Talked to a rep at B&M this AM and he was at a loss as to the difference in flex plate appearance from mine to what it shows now.
But ours is a forged steel crank and all is well as far as we can tell.
Sorry I couldn't help, Joe Joe, thanks for going the extra step and calling B&M. I was planning on doing that this morning but you doing it was much better. You could start the conversation with "I bought this flexplate from you..." If I had been asked any details I'd been dead in the water.
[Re: 6PakBee]
#2274858
03/23/17 04:06 PM
03/23/17 04:06 PM
750-h2
.....buy weight kit part # P4120241. This kit is for externally balanced cast cranks as well as the externally balanced 1970 & 1971 440 six pack engines and all other 440's with heavy rods[all have forged cranks]. Kit comes with a template and instructions. I saw that kit during my search and every time it popped up the application was listed as: Torque Converter Balance Weight & Positioning Template Kit Fits Most 1971-'79 383/440 (with cast crank) Fits 1971-'92 360 Fits 1971-'76 340 (with cast crank) There is no mention of the '70 heavy rod steel crank 440. Do you have a copy of the instructions or some other documentation that indicates this kit has this coverage? Appreciate the help. 6PakBee here is a link to the Mopar performance catalogue. Go to the auto trans section and look at the torque converter application chart page 91. There they tell you to use the weight kit P4120241 with the 440 six pack with heavy rods. http://www.mopar.ca/assets/pdf/restoration/CATALOGUEDERESTAURATION2007.pdf
[Re: 6PakBee]
#2274860
03/23/17 04:09 PM
03/23/17 04:09 PM
Posts: 1,317 Ohio
jlatessa
Ohio
Aha, good find John, that's what ours looks like. Now why the B&M guy didn't know about it????
You're all set now 6PakBee...
Joe
EDIT, the ad from Summit says "Not available" What the He__!
[Re: 6PakBee]
#2274868
03/23/17 04:21 PM
03/23/17 04:21 PM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
B&M 10238 is the correct flexplate for the forged crank, heavy (6 pack) rod 440 that is externally balanced.
It looks like they don't make it anymore? I've checked every website and no one has it (jegs, summit, mancini, etc.)...B&M's own website no longer shows it.
I may still have one out in the shop. The motor I ran it with ('71 HP 440) is now in a 4 speed car...when I freshened up the motor I had it internally balanced so I wouldn't have to deal w/ that ext. crap anymore.
[Re: 750-h2]
#2274878
03/23/17 04:37 PM
03/23/17 04:37 PM
6PakBee
North Dakota
Thanks for the link! It's somewhat disturbing that one has to go to a 10 year old catalog but I guess that is progress! Thanks again.
