69 Valiant grille screw kit #2274087
03/22/17 03:20 AM
03/22/17 03:20 AM
lancaster,california
johnnycuda Offline OP
Hey guys, does any of you know who sells or produces a grille screw/hardware kit for a 69 Valiant?, I've checked with Layson's, Tony's, Year One and Classic Industries with no luck. I bought the car and the grille was on the front seat, actually two were, but no hardware. It gets painted this weekend B5.
Thanks in advance,
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: 69 Valiant grille screw kit [Re: johnnycuda] #2274182
03/22/17 12:28 PM
03/22/17 12:28 PM
ohio
bbtrux Offline
bbtrux  Offline
ohio
Would 70-72 valiant/duster stuff work? Would assume more likely to be found than 69 valiant 1 year specific stuff.
Re: 69 Valiant grille screw kit [Re: johnnycuda] #2274246
03/22/17 02:47 PM
03/22/17 02:47 PM
I honestly don't know, all of it was gone when I got the car, was hoping somebody here has run into this. The Spring Fling is coming up in 2 weeks, maybe a vendor there will know.
Re: 69 Valiant grille screw kit [Re: johnnycuda] #2274334
03/22/17 04:54 PM
03/22/17 04:54 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Look for the best examples on other cars. Talk to the owners then go to the venders. Most likely you'll have to buy the screws from a place like Restoration Specialties Supply Inc. So go back to the owners of similar cars and see if they will help. Sometimes there are some oddball screws such #6 oval head on #8 sheet metal screw.
Parts and shop book may help too. Probably won't give you all the details but may show how many and how many different types, whether its a self tapping or there is a retaining clip.
Re: 69 Valiant grille screw kit [Re: Mattax] #2274392
03/22/17 06:52 PM
03/22/17 06:52 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted By Mattax
Look for the best examples on other cars....
iagree
Unless you have the complete specs for a fastener, the only real way to identify what is correct is to look at an installed one. Otherwise you'll probably end up with a lot of hardware you can't use.....trust me on this one.
Re: 69 Valiant grille screw kit [Re: johnnycuda] #2274455
03/22/17 08:59 PM
03/22/17 08:59 PM
Yep, I was going to walk thru the car show area and ask around.
Re: 69 Valiant grille screw kit [Re: johnnycuda] #2274795
03/23/17 02:11 PM
03/23/17 02:11 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Bring some way to figure out the details. In this respect a junkyard is easier. Someone will have to be willing to remove a screw(s) to get a good measurement. To easy to chance a vernier caliper or machinest's rule possibly scratching the trim/grill surface.
