Small block heads (again) #2274179
03/22/17 12:21 PM
03/22/17 12:21 PM
central illinois
65dodgebob Offline OP
central illinois
I know we beat this topic to death, but I am looking for a good set of magnum style heads to put on a 318, maybe later a 340. Street car, don't need 400 cfm.anyone have any experience with dragway tools heads? Look good.
Re: Small block heads (again) [Re: 65dodgebob] #2274198
03/22/17 12:48 PM
03/22/17 12:48 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Never heard of them
Re: Small block heads (again) [Re: SpareParts] #2274205
03/22/17 01:08 PM
03/22/17 01:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Never heard of them but someone's gotta be the first sucker, eeeeere I mean buyer. Let us know how they work out.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small block heads (again) [Re: pittsburghracer] #2274213
03/22/17 01:27 PM
03/22/17 01:27 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
LMAO
Re: Small block heads (again) [Re: 65dodgebob] #2274237
03/22/17 02:26 PM
03/22/17 02:26 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Re: Small block heads (again) [Re: 65dodgebob] #2274243
03/22/17 02:39 PM
03/22/17 02:39 PM
gregsdart Offline
gregsdart  Offline
I posted on a web site asking, and a member there named RAMM said he had tried to work with a set. Rough casting, not very good flow like EQs and maybe even stockers. EQs have a good rep. Is it worth $200 to gamble on them? Probably not, as I am guessing you want to run them as shipped?
Re: Small block heads (again) [Re: 65dodgebob] #2274247
03/22/17 02:48 PM
03/22/17 02:48 PM
ccarson Offline
ccarson  Offline
Let us know how that works out for you?
RHS EQ's and Edelbrock are better proven alteratives
Re: Small block heads (again) [Re: 65dodgebob] #2274286
03/22/17 03:56 PM
03/22/17 03:56 PM
P
Porter67 Offline
Porter67  Offline
P
Them be the china man cast iron version.
Id almost try anything, but probably not these.
http://www.ebay.com/itm/Chrysler-318-360-Magnum-Cylinder-Head-Bare-/302075766228?hash=item46551e65d4:g:88IAAOSwCGVX3EJB&vxp=mtr
Re: Small block heads (again) [Re: 65dodgebob] #2274292
03/22/17 03:59 PM
03/22/17 03:59 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
EQ. Period.
Re: Small block heads (again) [Re: cudadoug] #2274300
03/22/17 04:08 PM
03/22/17 04:08 PM
central illinois
central illinois
I am planning on doing gasket match and basic bowl blend and checking out the valve job, I like the EQs, just was curious if anyone has played with the drag way tool heads. Thanks for the input.
Re: Small block heads (again) [Re: 65dodgebob] #2274322
03/22/17 04:40 PM
03/22/17 04:40 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I had one set of those they are very rough castings, very small ports I did not have em flow tested but I bet they flow a lot worse than even the stock ones. I decided it was better to run a cracked stock one that is otherwise good than to ever buy another of those piles of junk.
