Tight fit A body #2273295
03/20/17 10:01 PM
03/20/17 10:01 PM
Virginia Beach, VA
O
Old School Offline OP
O
Virginia Beach, VA
Putting my Rb motor in my 68 Cuda. It has a QuickTime bellhousing. As you can see in the picture the bracket for the z bar hits the body. Motor still needs to go back a little more. Anybody else run into this? I don't want to just smash it in with a hammer. Thinking about cutting an access hole and then have a bolt in cover. Thoughts??
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Tight fit A body [Re: Old School] #2273362
03/20/17 11:32 PM
03/20/17 11:32 PM
I would not smash it. I cant quite see in the pic what is there but here is a BTT for ya.
Re: Tight fit A body [Re: Old School] #2273370
03/20/17 11:43 PM
03/20/17 11:43 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
RB in A-body is always a tight fit. How do you plan to get headers through that opening? work
I'd get rid of the Z-bar entirely, and use a hydraulic clutch linkage (not necessarily a hyd. TO bearing though). It is much easier to route a single #3 braided Teflon hose than a mechanical linkage. twocents
Re: Tight fit A body [Re: Old School] #2273465
03/21/17 01:55 AM
03/21/17 01:55 AM
CT - just outside Hartford
Crazy73 Offline
Crazy73  Offline
Fitting a 383 4-spd with manifolds and power steering in my '68 cuda was pretty close to a nightmare - I can't imagine trying that with an RB!
Pete
-1968 Barracuda 4spd 383-6pk
Re: Tight fit A body [Re: Old School] #2273517
03/21/17 08:13 AM
03/21/17 08:13 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Can you grind a little off the bracket?
Re: Tight fit A body [Re: Old School] #2273578
03/21/17 11:30 AM
03/21/17 11:30 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Modify the bracket. Or go hydraulic.
Re: Tight fit A body [Re: mopowers] #2274012
03/21/17 11:47 PM
03/21/17 11:47 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
It's in. I had to cut most of the bracket off. Also had to peen the floor pan. Everything fits fine now, even all the mechanical clutch linkage.
Re: Tight fit A body [Re: Old School] #2274029
03/22/17 12:14 AM
03/22/17 12:14 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
AWESOME !!! Myself, I am not a fan of the hydraulic setups. beer
Re: Tight fit A body [Re: Old School] #2274048
03/22/17 12:50 AM
03/22/17 12:50 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
That last pic of yours Old School is giving me a woody smile I wonder how long I will have to wait for an aluminium block.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Tight fit A body [Re: Old School] #2274720
03/23/17 12:03 PM
03/23/17 12:03 PM
Crazy73 Offline
Crazy73  Offline
Nice job!
Pete
