69 Pop out window hardware #2272403
03/19/17 03:51 PM
03/19/17 03:51 PM
So. Illinois
bronze69 Offline OP
bronze69  Offline OP
So. Illinois
It has been a few years since tearing my car apart, and I am to the point of installing my rear pop out windows. The problem is, I cannot remember which screws held the rear latch bracket to the quarter panel. I have purchased the ICCA fastener guide, which shows every nut, bolt, and fastener on the car except this one. And all of my other cars are hardtops, so I can't check them. If anyone has specs and/or pics of the correct hardware, I would GREATLY appreciate it.
68 Gold Met. 383-4spd Roadrunner 69 T5 Hemi 4-spd Roadrunner 70 Limelight 440-6 Auto Superbird
Re: 69 Pop out window hardware [Re: bronze69] #2272531
03/19/17 07:54 PM
03/19/17 07:54 PM
Brantford Ontario
69_SIX_PACK Offline
69_SIX_PACK  Offline
Brantford Ontario
Mine just had the same screws that were holding on the front frame.
Re: 69 Pop out window hardware [Re: 69_SIX_PACK] #2272823
03/20/17 09:20 AM
03/20/17 09:20 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
The back one is a bit longer due to the casting thickness of the hasp base. See below.
Hope this helps.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: 69 Pop out window hardware [Re: Big D A12] #2273400
03/21/17 12:30 AM
03/21/17 12:30 AM
So. Illinois
bronze69 Offline OP
bronze69  Offline OP
So. Illinois
Thanks a bunch guys. That helps tremendously.
This was one of those projects that got torn apart around 2004 with good intentions. But got pushed to the side for other reasons. With a couple of shop cleanings, everything that was put somewhere in an organized manner got moved.
