useing GM LS computer etc on 5.9 magnum
#2272889
03/20/17 12:05 PM
03/20/17 12:05 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
A yew years ago a member on here was talking about making a fuel injection kit to use on a big block. By that I mean he was going to use a GM LS computer, coil and wiring harness. I was just wondering oh far he got with it. I am asking because I am getting ready to put a dodge 5.9 magnum with the factory fuel injection in my dart sport. But got to wondering if anybody used the GM computer etc to run the dodge engine. I just figured the GM computer would be easer to tune for boost etc. Also this is all MIke aka p-Body faults. I saw a pic of a LA engine with coil by plug and want to do that to my engine
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
Re: useing GM LS computer etc on 5.9 magnum
[Re: dvw]
#2273016
03/20/17 02:39 PM
03/20/17 02:39 PM
mopar65
You need to change the tone ring to the GM configuration. Doug I remember that now after you said that. Know anything about if the GM computer will work with the 46RE trans? If not and I decide to do the GM conversion my uncle said he has the early 518 trans I can use. Also wasn't you the one that talked about selling a kit to add a turbo? If so did you ever come out with a kit? I am really wanting to put a turbo on my 360 next year.
support our troops
[Re: mopar65]
#2273024
03/20/17 02:48 PM
03/20/17 02:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You need to change the tone ring to the GM configuration. Doug I remember that now after you said that. Know anything about if the GM computer will work with the 46RE trans? If not and I decide to do the GM conversion my uncle said he has the early 518 trans I can use. Also wasn't you the one that talked about selling a kit to add a turbo? If so did you ever come out with a kit? I am really wanting to put a turbo on my 360 next year. The turbo kit was his son(Scott).. with the 62 ply
[Re: MR_P_BODY]
#2273123
03/20/17 05:31 PM
03/20/17 05:31 PM
mopar65
You need to change the tone ring to the GM configuration. Doug I remember that now after you said that. Know anything about if the GM computer will work with the 46RE trans? If not and I decide to do the GM conversion my uncle said he has the early 518 trans I can use. Also wasn't you the one that talked about selling a kit to add a turbo? If so did you ever come out with a kit? I am really wanting to put a turbo on my 360 next year. The turbo kit was his son(Scott).. with the 62 ply Thanks Mike for correcting me. At only 46 my CRS gets worse everyday
support our troops
[Re: mopar65]
#2273157
03/20/17 06:11 PM
03/20/17 06:11 PM
MR_P_BODY
You need to change the tone ring to the GM configuration. Doug I remember that now after you said that. Know anything about if the GM computer will work with the 46RE trans? If not and I decide to do the GM conversion my uncle said he has the early 518 trans I can use. Also wasn't you the one that talked about selling a kit to add a turbo? If so did you ever come out with a kit? I am really wanting to put a turbo on my 360 next year. The turbo kit was his son(Scott).. with the 62 ply Thanks Mike for correcting me. At only 46 my CRS gets worse everyday LOL.. dont worry.. my CRS is far worse.. plus a couple of strokes
[Re: mopar65]
#2274428
03/22/17 08:06 PM
03/22/17 08:06 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Why when you can do what ever you want on stock magnum efi with sct tuning? Contact Ryan Hogan at FRP tuning
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: slammedR/T]
#2274751
03/23/17 12:47 PM
03/23/17 12:47 PM
mopar65
Why when you can do what ever you want on stock magnum efi with sct tuning? Contact Ryan Hogan at FRP tuning Was just mostly to see if anybody has done it. Also how friendly is the stock dodge with boost. But thanks for the contact info. I will be getting in touch with him soon
support our troops
[Re: mopar65]
#2274910
03/23/17 05:48 PM
03/23/17 05:48 PM
slammedR/T
Dakota and ram guys have been making 550 to 600 whp on stock magnum short blocks, EQ heads and Ryan tuning with SCT on stock dodge truck EFI system. I believe they are using a GM 3 bar map sensor but Ryan would know all that for sure.
