Neutral switch question
#2272851
03/20/17 10:54 AM
03/20/17 10:54 AM
Posts: 425 Eastern Ontario
shaker340
Eastern Ontario
I am wiring a 1964 Dodge D100 with a hot rod wiring kit. They give one wire which is positive 12v. I have the trans wiring and connector, but not the mating connector. I do not have back up lights in this truck, where would I wire the other two wires to? Most schematics show going to back up light switch. And where can I get the mating connector?
Thanks, Mike
2008 Challenger SRT8 1940 Chrysler Royal coupe
Re: Neutral switch question
[Re: stumpy]
#2273048
03/20/17 03:32 PM
03/20/17 03:32 PM
shaker340
Eastern Ontario
Stumpy, exactly what I wanted to hear, only connect to the center pin and not connect the other two. I installed 1974 440 and 727 trans for those who are curious.
