What to do with 74 Challenger Ralley (engine choice) #2272844
03/20/17 10:34 AM
03/20/17 10:34 AM
Ohio
O
Otto Offline OP
Otto  Offline OP
O
Ohio
Opinions please.
I have a 74 Ralley (real ralley car) originally w/ 318 auto air.
I do NOT have the original motor.
This car is a super clean California car.. fully restored.
Question is this...
Should I go thru a 1971 318 that I have to put in it..
OR , Should I install a 440 that I have ?
What would do better on resale when that time comes ?
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2272879
03/20/17 11:49 AM
03/20/17 11:49 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Most people are going to want a 440.
If it were mine I would build a 408 out of a 360.
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2272957
03/20/17 01:34 PM
03/20/17 01:34 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
gen 3 hemi
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2272964
03/20/17 01:41 PM
03/20/17 01:41 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Stroked small block.
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2272977
03/20/17 02:00 PM
03/20/17 02:00 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Depends on what your intention with the car is. Full street car - small block, street/strip - 440. Could use a 318 or 360 and build it very nicely for the road and dress up as a 318 for a "original" look.
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2272996
03/20/17 02:21 PM
03/20/17 02:21 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
4" stroke crank in your 318 with ported factory 360 heads or a set of edelbrocks if you don't care about non-stock look. Tell everybody some 318s just run better than others.
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2273054
03/20/17 03:43 PM
03/20/17 03:43 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Magnum headed 408 Dress to look like a 318. Can even use LA valve covers.
**Photobucket sucks**
Re: What to do with 74 Challenger Ralley (engine choice) [Re: 70Cuda383] #2273056
03/20/17 03:44 PM
03/20/17 03:44 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Well built 408 will make an easy 500 hp and be much lighter than a big block. It'll handle way better than a big block, keeping true to the ralley package
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2273090
03/20/17 04:35 PM
03/20/17 04:35 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
"This car is a super clean California car.. fully restored."
By fully restored are you saying the engine bay still retains its OEM appearance? If so, I would not consider changing to an RB.
Stroked LA all the way.
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2273091
03/20/17 04:35 PM
03/20/17 04:35 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Stroker 360.
Sheldon
Sheldon
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2273186
03/20/17 07:01 PM
03/20/17 07:01 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
E-bodies handle WAAAAY better with a small block. Gen3 might be a way cool upgrade. Have you seen those engine/trans. running on a pallet deals?
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Dave Hall] #2273229
03/20/17 08:24 PM
03/20/17 08:24 PM
dogdays Offline
dogdays  Offline
You don't have the original engine so it'll never really be "restored".
GIII Hemi, there's no question. Remove at least 200# of ugly fat off the front end, double the mileage, low maintenance powertrain. What's not to like?
R.
Re: What to do with 74 Challenger Ralley (engine choice) [Re: dogdays] #2273313
03/20/17 10:23 PM
03/20/17 10:23 PM
IN
ahy Offline
ahy  Offline
IN
Whatever you choose I'll suggest you build it well so it can be effectively and pleasantly driven. Careful specs, careful machining and preferably quench and decent compression for both fun and fuel mileage on pump gas.
A well built 318, 360, stroker small block or big block or Hemi. What you want.
I went with a BB. 496B, Al heads, manifold and WP. Also Sanden AC compressor. It probably weighs less than the iron 318 I replaced. With suspension upgrades it handles pretty darn well. Pics are from an X country drive - >4000 miles in 9 days - and the road course.
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Pacnorthcuda] #2274460
03/22/17 09:12 PM
03/22/17 09:12 PM
Ohio
O
Otto Offline OP
Otto  Offline OP
O
Ohio
completely stock.. all the way to all A/C components in place.
Fully painted.. looks nicer than showroom new.
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2274461
03/22/17 09:19 PM
03/22/17 09:19 PM
Then that answers the question. A completely stock engine bay is very difficult to replace. The fact you are starting with one means it should be retained.
LA all the way.
...and I'm into MODIFIED E bodies!!! Even I wouldn't change it.
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2274810
03/23/17 02:48 PM
03/23/17 02:48 PM
Colorado springs, CO
Arominus Offline
Arominus  Offline
318 with aluminum heads/intake/headers, a decent cam and a beefed up 904 or A500. It would be awesome and light.
1957 Desoto Firesweep 2dr
392/A518 builds in progress.
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2274925
03/23/17 06:26 PM
03/23/17 06:26 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The important question is; What are your going to do with the car once the motor is in it?
I see so many "restored" or "hot rod" cars that sit in garages and seldom see the light of day, that I'm baffled. Why did they spend all that money and not drive the car?
Put in whatever motor in it that will encourage you to get the car out on the road and enjoy it, and let others enjoy it.
Personally, I'd do a mild performance upgrade on a 318 and drive the wheels off of it. A mild, fun to drive, 318 stands a better chance of getting driven than a bone stock 318, or a monster street brawler motor with bad street manors. Gene
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2275190
03/24/17 02:18 AM
03/24/17 02:18 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
So the original 318 for my 70 Sport Satellite was long gone . . . I built a 360 to live in it's place . . . although it looks like a "stock" 318 (with a 4bbl carb though - and air cleaner from 72 340 with big vac operated flap on right rear side) ... I drive my car, and yes it all works - a/c, and cruise control, etc. . . .
As was said, what are you wanting to do with your car ??? You want to go fast, then build whatever engine you want. You want to look stock/go fast, build small block stroker to look like 318. You want to enjoy your car, drive it all over the place, get decent gas mileage, leave the 318 and just drive and enjoy . . . it all comes down to what you want . . . you gotta build the car for you . . . .
Good Luck,
Cheers,
Mark
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2275249
03/24/17 09:13 AM
03/24/17 09:13 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I would stroke the 318 or find a 360, small block E-bodies are awesome.
<<<<runs 11's....everyone thinks it's a big block or Hemi until we pop the hood. Full street car.
Re: What to do with 74 Challenger Ralley (engine choice) [Re: Otto] #2275267
03/24/17 10:29 AM
03/24/17 10:29 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Opinions please.
Being it is a 318 Rallye, it is on the fence as to have a better resale with a 318 vs a 440. If it was a 360 Rallye, the answer would be clear, keep it OEM as possible. If it was a standard Challenger, a 440 would likely have a better resale.
Although there are buyers that would prefer a 440, I think most prefer OEM or at least an OEM look. If you make any changes, make ones that are easily reversed.
If it were mine, I'd pull and save the original drivetrain, pick up another 318, stroke it to 390 and detail under the hood to appear OEM as possible like a12rag's Satellite above.
