Page 129 of 180 1 2 127 128 129 130 131 179 180
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2272482
03/19/17 06:19 PM
03/19/17 06:19 PM
fullmetaljacket Offline
He means the cat walk section running along the whole brim. Just has to be welded well and shut. Grounded smooth after that, it becomes more beautiful and wind slick. Probably a few pounds right there. The spot welds that held that portion together was shoddy at best from the factory.
I would jig and or clamp the cars front longitude together while you cut to keep things straight and level.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2272530
03/19/17 07:54 PM
03/19/17 07:54 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Copy that! up Also cleaned up by the steering box mount.Will just drill holes next to existing holes than wack off the remaining edge. Then weld everything nice and strong! weld
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2272541
03/19/17 08:35 PM
03/19/17 08:35 PM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
You planning on tying the outside of that steering box support back into the K frame? -Trent
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Real world weight loss program and it` cost.......... [Re: MadMopars] #2272546
03/19/17 08:47 PM
03/19/17 08:47 PM
I also agree, make sure to tie that steering boss mount back to the K or else you'll find a whole lot of swagger.
When I cut off and ground smooth all my existing motor mounts and bosses, I made sure to tie up the steering better than the factory did.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2272589
03/19/17 10:14 PM
03/19/17 10:14 PM
Here's a theoretical question for guys. If I got my hands on one of those (200) lbs (LOL) lighter Challenger Demons, how much weight do you think I could shave off taking into account that these are different times, parts and car construction?
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2272640
03/19/17 11:11 PM
03/19/17 11:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
before and after
Re: Real world weight loss program and it` cost.......... [Re: dvw] #2272681
03/20/17 12:16 AM
03/20/17 12:16 AM
DVW. Did you account for how much weight you shaved off or put back on to box it in?
Perhaps you ended up with the same weight but with more room?
Itis: what DVW is mentioning are the four trim excess materials you see on the very top, sides and bottom of his picture.
Re: Real world weight loss program and it` cost.......... [Re: MadMopars] #2272748
03/20/17 02:32 AM
03/20/17 02:32 AM
hemi-itis Offline
hemi-itis  Offline
Will be moving the steering box over toward the rail.I'm also told to cut the flanges on the "k". sawzall
Engine parts should start showing up this week runaway
It seems the "c" channel I used to raise the engine plate was distorted for some reason,,,,,,,,,,,,,, whistling
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2272805
03/20/17 07:21 AM
03/20/17 07:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Definitely weighed less done. Missing in the picture are the tube support and the tie down loops. The plate was 1/8", I believe the piece was 1.5" x 16" if I remember correctly.
Doug
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2272935
03/20/17 01:01 PM
03/20/17 01:01 PM
hemi-itis Offline
hemi-itis  Offline
Doug,did you use the original steering box mount or did you install a new plate? I think I will use the original AMERICAN STEEL that is there, clean it up after moving the box and reinforce.
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2273339
03/20/17 11:01 PM
03/20/17 11:01 PM
I would use the existing American steel and reinforce with good plate of the same gauge. That's what I did with mine.
Why is it that you have to move the box?
Are the head exhaust ports and headers giving an eviction notice to the steering box?
Are you now going to have to run a heim joint type of steering linkage?
Perhaps a Rack would be better at that point?
Itis, did you peep Haze's new 330 sedan?
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2273417
03/21/17 12:51 AM
03/21/17 12:51 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used the original reinforced with tubing. Hard to see but thre are 2 tubes .090"x.750" moly
Doug
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2273422
03/21/17 12:55 AM
03/21/17 12:55 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Dvw, those steering box bolts are WAY too long... haha
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Real world weight loss program and it` cost.......... [Re: dvw] #2273448
03/21/17 01:25 AM
03/21/17 01:25 AM
Just outstanding DVW.
Itis, we need to talk.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2273480
03/21/17 02:25 AM
03/21/17 02:25 AM
hemi-itis Offline
hemi-itis  Offline
As much as I would like to duplicate what Doug did with his "K",It would be harder to do in the car.I was also surprised at the mere 2 lbs that chunk was that was cut outta my k.The amount of work to remove the flanges and weld everything back up will not be done or the 3 or 4 lbs net.The aluminum heads with stands should be 85 to 90 lbs.An aluminum radiator should be at least 20 lbs,,,,whaddia think?
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2273527
03/21/17 09:30 AM
03/21/17 09:30 AM
The Rad will only net about 10 Lbs. Take off your electronic control boxes and or any ignition boxes before welding on the car.
Re: Real world weight loss program and it` cost.......... [Re: OUTLAWD] #2273554
03/21/17 10:53 AM
03/21/17 10:53 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Agreed, there's more than a few bolts I should address.
Doug
Re: Real world weight loss program and it` cost.......... [Re: dvw] #2273720
03/21/17 03:34 PM
03/21/17 03:34 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Your car is so clean...pretty sure the paint on your K-member is better than the paint on my hood.
Re: Real world weight loss program and it` cost.......... [Re: OUTLAWD] #2273748
03/21/17 04:12 PM
03/21/17 04:12 PM
His K-member can be a display at any show including SEMA and win best of show.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2273871
03/21/17 07:45 PM
03/21/17 07:45 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
rant
Jealousy is an ugly thing... whistling
...FAFO...
