360 Sonic Test Results - 408 Stroker #2272405
03/19/17 02:57 PM
03/19/17 02:57 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline OP
P
I have a line on 2 - 360 blocks, a 72 and a 73 both unmolested. Considering using either one for a 408 stroker. The guy had both blocks sonic tested, see attached. Which one would be the best choice, most likely will go .030 over? Mostly street driven and a few possibly a few passes.
Re: 360 Sonic Test Results - 408 Stroker [Re: Pntastar69] #2272411
03/19/17 03:10 PM
03/19/17 03:10 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I would repost this in the Race forum where the guys in the know are more likely to see it.
Re: 360 Sonic Test Results - 408 Stroker [Re: Pntastar69] #2273017
03/20/17 01:39 PM
03/20/17 01:39 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
The 1972 is the better block. Major is thicker. That block will work well.
