Solid roller vs. Solid flat tappet #2272044
03/18/17 10:56 PM
03/18/17 10:56 PM
junction city oregon
V
viperblue72 Offline OP
V
After adding up the cost of going roller vs solid I need to decide if the gains are worth the significant cost being that I already have crane ductile rockers, pushrods, and springs.
Have any of you switched from solid to solid roller? If so what was the et or horsepower gain?
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272049
03/18/17 11:03 PM
03/18/17 11:03 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
My machinist told me that a solid roller is worth 15 hp over a solid flat tappet (in a race application).
That is at same specs. A solid roller would allow you to maximize lift and duration over a flat tappet, though.
[image][/image]
Re: Solid roller vs. Solid flat tappet [Re: sgcuda] #2272056
03/18/17 11:14 PM
03/18/17 11:14 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
And no chance of a cam not broke in properly.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272058
03/18/17 11:27 PM
03/18/17 11:27 PM
Cab_Burge Online work
Cab_Burge  Online Work
The best and biggest thing I found on switching from a solid flat tappet cam to a solid roller cam with similar or the same lift and duration was the roller cams all had a lot more piston to valve clearances from 20 BTDC to 30 ATDC thumbs
The lobe designs help the motor make more power shruggy
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272060
03/18/17 11:30 PM
03/18/17 11:30 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
If you have all of that stuff and want to use it, solid flat tappet. If you don't mind spending some money and want to put a larger cam ( >.700ish lift) you will want to go roller ,aside from all of the other flat tappet break in issues.
It all depends on displacement, cylinder head capability, and what you are looking for out of your engine package. If you are running a 350+ CFM head the characteristics of the solid roller lobe (faster valve movement) and added lift might surpass the output of the biggest solid ft cam when it becomes unstable due to the lower spring pressures.
Whatcha building anyway?
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272096
03/19/17 12:37 AM
03/19/17 12:37 AM
V
V
I am building a 512 low deck.
11.7 to 1
Sidewinder heads ported will flow 300ish.
Mostly strip car, some street.
I plan to optimize the combo for bracket racing. But within reason so that it's a reliable combo.
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272098
03/19/17 12:44 AM
03/19/17 12:44 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
If it was me I'd roll with what you have a keep some cash set aside for something else, like good shocks. 11.7CR will help things along. With the right cam you can run that thing on 93 with a splash of 110 for safety margin.
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272167
03/19/17 04:56 AM
03/19/17 04:56 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I figured since my car was a street car and I am not out to set a world record I would use the solid flat tappet. One reason is that its a cheaper setup and cash is always needed around me. And the second reason is I dont want to pull the lifters every few years to check them. I have heard of roller lifters loosing a needle bearing and wasting an eng. Now I know many guys do run them but I figured I would want a nice one and it would need good spring pressure. Who knows I could have run a roller and got away with it for many years but I would feel better pulling the lifters every few years and check them for piece of mind since I put a good amount of miles on my car each year. Like Dwayne Porter told me that valve float is bad with roller cams so you need to run much more spring pressure with a nice size roller you plan to race some. Valve float can let the cam hammer the lifter some which is tuff on the roller needles. So you do want to be sure you run the proper spring pressure with the roller. Yes it will make some more power but I have no complaints with my flat tappet cam. And I am not trash talking rollers as tons of people run them and do fine but I just would not want to be the guy that has a roller lifter come apart because I did not pull and check them every few years. Good luck which ever you choose. Ron
Re: Solid roller vs. Solid flat tappet [Re: 383man] #2272216
03/19/17 10:53 AM
03/19/17 10:53 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i'm agree with Ron on the subject. i'm building 511 as well but mine will see more street than strip. I had the cam nitrated and i'm using the EDM lifters that oil directly to the lobe. will break in on single springs with good oil. wont have to pull roller lifters every 5 yrs to have rebuilt or worry about losing bearing out of them any more.
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272242
03/19/17 11:26 AM
03/19/17 11:26 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I'm also with Ron on this. It's the classic trade off of performance vs cost vs reliability. If I had everything but the cam in my posession, and money isn't hanging from a tree in my yard, I would be looking seriously at a solid flat tappet. You're looking at around 2k for the entire roller set up incl rockers and pushrods or 300 for custom solid flat and lifters. If starting from scratch w no money concerns, roller all the way.
2 kids and a dog
Re: Solid roller vs. Solid flat tappet [Re: TonyS451] #2272255
03/19/17 11:48 AM
03/19/17 11:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have both set ups right now.. normally
I would run a roller but I went with a SFT
a couple of months back so I could run less
spring pressure.. I have the EDM hole in both
set ups.. the reason I did go with the SFT
was because the injection didnt like the roller
set up... but I'm finding out it really wasnt
the cam that was the issue... I think if you
were to look back you might find that SFT cams
fail far more often than roller cams.. so far
I have not had a roller cam/lifters fail in over
20 years of running a roller cam...I will see how
it goes with the SFT
wave
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272277
03/19/17 12:28 PM
03/19/17 12:28 PM
V
V
Looks like solid flat tappet it is. Thanks for the reassurance. About the roller I do like the idea of no break in. I added the cost and it would cost me roughly 2k to go roller vs 5-600 solid lifter.
Jeremiah my thoughts exactly on running pump gas. When i race I will use some 110 but for cruising around I'll try pump fuel with a splash of 110.
I thought there was a chance this could be a more controversial choice, but it appears solid is the clear winner dollar for dollar. There are other areas I can use the money difference that will be better performance wise.
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272279
03/19/17 12:34 PM
03/19/17 12:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
11.7 to 1
My Isky solid roller has been awesome for years mostly street which makes it more impressive w/gentle lobes but VERY nasty when stomped. Solid body lifters rebuilt once and still rockin.............Do it........ beer
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272283
03/19/17 12:44 PM
03/19/17 12:44 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
There for a while we didn't seem to have many (if any) good choices for flat lifters. But now we have a couple of good choices. The EDMs have gotten good reviews. And Barton has a tool steel lifter that I have had good service from. So, I think we have some choices now for flat tappets that can rival or exceed rollers for dependability and longevity. At least in some applications.
Master, again and still
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272285
03/19/17 12:48 PM
03/19/17 12:48 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I normally run the purpleshaft solid flat tappets but my '69 Dart had a 706/661 lift solid roller, raced it for 5 years without doing any roller lifter maintenance although I probably should have.
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272305
03/19/17 01:09 PM
03/19/17 01:09 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have never heard of a roller cam being wiped out upon startup. Yesterday at the track a guy was telling me about his experience of tearing down his new built engine to clean out the metal. I myself have did the same over the years. I'd look at the cost of pulling the engine and tear down and rebuild in your decision . Cheaper ,not that anything is nowadays as they say is not always the best way to go. From running flat tappet cams from the start in the 60's I now have a roller kit on the shelf for the next rebuild.
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272316
03/19/17 01:22 PM
03/19/17 01:22 PM
V
V
That is definitely one reason that I love roller cams is no more fear of failure at break in. And if I were starting from scratch it would be roller all the way. And that's what I have done in the past. But in my current case it appears the $ to hp gain etc. won't be worth the extra 1400 cost.
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272319
03/19/17 01:24 PM
03/19/17 01:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What are you looking at for lift and duration
on your cam.. what kind of HP are you thinking
and is it a SB or BB.. you have to take into
account the rpm you will run
wave
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272338
03/19/17 02:00 PM
03/19/17 02:00 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
If I ever get my Dart out of paint jail, I'll let you know how my mushroom cam is working. Very similar rates of lift/duration to a moderate roller (mine after minimal regrinding to restore lobe taper is 272@.050, .652 gross lift) without the "extra 1400" for valvetrain up
Although I was extremely nervous breaking it in! Outer springs only, good oil, lots of zinc. It's a trade off for sure...
Re: Solid roller vs. Solid flat tappet [Re: viperblue72] #2272350
03/19/17 02:22 PM
03/19/17 02:22 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
After rolling a cam on a 360 I vowed never to run a flat tappet again. Still no idea what caused it. Chased down all the obvious stuff and never found anything.
Current motor is a mild 512 low deck build. Already bought a Comp XR280 roller setup.
