440 six pack fuel bowl #2271576
03/18/17 04:21 AM
03/18/17 04:21 AM
Brisbane Australia
572B1 Online content OP
572B1  Online Content OP
Brisbane Australia
Hi, I have a stripped needle and seat on front fuel bowl. carb number is 4382. can you buy new fuel bowls for 440 six pack carbs. thanks in advance.
Re: 440 six pack fuel bowl [Re: 572B1] #2271596
03/18/17 07:56 AM
03/18/17 07:56 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Yes.
Re: 440 six pack fuel bowl [Re: jbc426] #2271600
03/18/17 08:13 AM
03/18/17 08:13 AM
Brisbane Australia
Brisbane Australia
Originally Posted By jbc426
Yes.
any contacts
Re: 440 six pack fuel bowl [Re: 572B1] #2271606
03/18/17 08:56 AM
03/18/17 08:56 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
http://www.promaxcarbs.com/
one of many places...
Re: 440 six pack fuel bowl [Re: 572B1] #2271607
03/18/17 08:58 AM
03/18/17 08:58 AM
P
Porter67 Offline
Porter67  Offline
P
Ebay is much cheaper then promax.
Re: 440 six pack fuel bowl [Re: Porter67] #2271609
03/18/17 09:13 AM
03/18/17 09:13 AM
Brisbane Australia
Brisbane Australia
I can't see any on ebay.
Re: 440 six pack fuel bowl [Re: 572B1] #2271610
03/18/17 09:22 AM
03/18/17 09:22 AM
P
Porter67 Offline
Porter67  Offline
P
Re: 440 six pack fuel bowl [Re: Porter67] #2271619
03/18/17 09:43 AM
03/18/17 09:43 AM
Brisbane Australia
Brisbane Australia
Thanks for the contact. but none of those fit a 440 six pack outboard carb, as they have no excelerator pump.
Re: 440 six pack fuel bowl [Re: 572B1] #2271637
03/18/17 10:24 AM
03/18/17 10:24 AM
P
Porter67 Offline
Porter67  Offline
P
Its all good but if you search the holley fuel bowls long enough you would find one, I just converted mine back from chrome bowls, with no pumps.
There are a couple guys on here that would have good used ones.
Re: 440 six pack fuel bowl [Re: 572B1] #2271660
03/18/17 11:15 AM
03/18/17 11:15 AM
New York
rarefish Offline
rarefish  Offline
New York
I'm reading this correct? That is that you have accelerator pumps on your outboard carbs? So what unusual.
Re: 440 six pack fuel bowl [Re: 572B1] #2271768
03/18/17 02:02 PM
03/18/17 02:02 PM
WA
tman Offline
tman  Offline
WA
You must have a mechanical setup.
Re: 440 six pack fuel bowl [Re: tman] #2271774
03/18/17 02:10 PM
03/18/17 02:10 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Think he's saying he needs a bowl with no pump provision, like factory end carbs.
Re: 440 six pack fuel bowl [Re: 572B1] #2271795
03/18/17 03:09 PM
03/18/17 03:09 PM
WA
tman Offline
tman  Offline
WA
Re: 440 six pack fuel bowl [Re: 572B1] #2271915
03/18/17 06:50 PM
03/18/17 06:50 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
contact member 62maxwgn. he rebuilds six pack carbs and should be able to help you out.
Re: 440 six pack fuel bowl [Re: macmic87] #2271962
03/18/17 07:51 PM
03/18/17 07:51 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Easy fix.
Re: 440 six pack fuel bowl [Re: 572B1] #2272055
03/18/17 11:12 PM
03/18/17 11:12 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
62maxwgn - ever run across any concentricity issues with the needle and seat machining bores, between the top threads and the bore for the sealing o-ring? Been having a problem trying to set the floats with a brand new set of carbs. Curious if this was a common problem on new carbs made 10 - 12 years ago. Threads on mine don't seem concentric with the sealing bore.
Re: 440 six pack fuel bowl [Re: mikemee1331] #2272074
03/18/17 11:58 PM
03/18/17 11:58 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: 440 six pack fuel bowl [Re: Sixpak] #2272083
03/19/17 12:12 AM
03/19/17 12:12 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Been through a "lot" and never had that problem,only leak issues were with after market needle/seat.
Re: 440 six pack fuel bowl [Re: 1969gtx] #2272084
03/19/17 12:15 AM
03/19/17 12:15 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I \
I think you will find no price listed means no stock,I've been dealing with them for years and finding more of the uncommon parts are not available.
Re: 440 six pack fuel bowl [Re: 572B1] #2272100
03/19/17 12:51 AM
03/19/17 12:51 AM
Philadelphia, PA
GTXKARL Offline
GTXKARL  Offline
Philadelphia, PA
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
