727 valvebody Q mod #2271608
03/18/17 09:04 AM
03/18/17 09:04 AM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
got a 727 transmission i got in pieces and needed a VB for another project ,
found mods , regular drilled channel wall ,and check ball behind valve
but there was a remowed channel wall in the lower channel plate anyone now whats that for?
Re: 727 valvebody Q mod [Re: Tobbe] #2271678
03/18/17 11:53 AM
03/18/17 11:53 AM
To clarify, does it look OE or does it look like someone added it?
Re: 727 valvebody Q mod [Re: Tobbe] #2271690
03/18/17 12:16 PM
03/18/17 12:16 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
Its not oe 😆
Re: 727 valvebody Q mod [Re: Tobbe] #2271809
03/18/17 03:27 PM
03/18/17 03:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The check ball is a common mod to block the 1-2 Shift Control Valve....makes a firmer 1-2 upshift.
Drilling the partition in the channel wall is common on full manual VB's but that location isn't familiar to me; are there any other similar drillings? The pic below shows the partition drillings (shown in orange) when making a RVMB.
Re: 727 valvebody Q mod [Re: Tobbe] #2271833
03/18/17 04:14 PM
03/18/17 04:14 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
Nothing like your pic .i cant see any mods more then this.
5.0 lever(aluminium?) is only step from oem
Re: 727 valvebody Q mod [Re: Tobbe] #2271895
03/18/17 06:17 PM
03/18/17 06:17 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
In the last set of 3 pics you show this looks very similar to the B&M HotShift kit that used to be available. I had installed a couple of these in the past.
I've attached the B&M TransPak install instructions and on P2 you will find the drilling template reference location which I think matches what you show.
What I'm confused by is that the original photos you showed at the top of the screen are pointing to a different passage...so maybe just confusion on my part??? LOL
Attached PDF document
Re: 727 valvebody Q mod [Re: Diplomat360] #2271913
03/18/17 06:44 PM
03/18/17 06:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nothing in the pics is out of the ordinary for a modified VB except for the removed partition wall in the second pic...that's a head scratcher. The steel separator plate doesn't show any mods, most kits have you drill out some of the orifices like Figure 5 in the PDF file above.
Re: 727 valvebody Q mod [Re: John_Kunkel] #2271922
03/18/17 07:01 PM
03/18/17 07:01 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
yes all ordinary exp this mod in lower channelplate , newer have seen this before in any kit , b&m , transgo etc , it looks nice machined not a hackjob
Re: 727 valvebody Q mod [Re: Tobbe] #2274091
03/22/17 03:59 AM
03/22/17 03:59 AM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
more pics ,looks like it connects to 2nd servo relese/direct feed
thumbnail_20170322_062129.jpgthumbnail_20170322_062140.jpgthumbnail_20170322_062148.jpg
