Big Block Mopar Alternator with Engine Plate #2271749
03/18/17 12:24 PM
03/18/17 12:24 PM
PA
Belvedere500ci Offline OP
PA
Looking to put an alternator on my 68 Barracuda with a 383. Car has a front engine plate. Looking for some pictures, companies, ideas. What's everyone running?? Thanks guys and Thanks Moparts!
1967 Plymouth Belvedere II 383
1968 Plymouth Barracuda 383
2005 Ram 3500 5.9Diesel
1979 Dodge Power Wagon 360
Re: Big Block Mopar Alternator with Engine Plate [Re: Belvedere500ci] #2271760
03/18/17 12:42 PM
03/18/17 12:42 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Jegs SBC chrome set.Cost about $40
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Big Block Mopar Alternator with Engine Plate [Re: Belvedere500ci] #2271763
03/18/17 12:55 PM
03/18/17 12:55 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Several options for a low mount like Hemi-itis posted, AR-Engineering makes a nice one.
Re: Big Block Mopar Alternator with Engine Plate [Re: Belvedere500ci] #2271791
03/18/17 01:50 PM
03/18/17 01:50 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
No "good" pictures to share buy I use the factory round back alternator and have a C.E. motor plate. The alternator is mounted in the stock location. All I did was add to the length of the lower adjusting arm/bracket where it mounts to the water pump housing, about 2 inches(?) and run a longer belt.
Works for me......
Re: Big Block Mopar Alternator with Engine Plate [Re: Belvedere500ci] #2271851
03/18/17 03:52 PM
03/18/17 03:52 PM
AndyF Offline
AndyF  Offline
I've sold a bracket kit to a bunch of folks over the last few years. It is designed to work with my motor plate and a short pulley but I would imagine someone with decent hot rod skills could make it work with other parts.
Re: Big Block Mopar Alternator with Engine Plate [Re: Belvedere500ci] #2271865
03/18/17 04:15 PM
03/18/17 04:15 PM
Ohio
lockjaw-express Offline
Ohio
AR Engineering makes the best engine plate by far, and in my case I mounted the Alternator bracket above on the back side of the plate, and went with a 150amp Denso Race Alternator.
Works great!
Mark
