Restoration services - Machine shp,Chrome, upholstery etc.
#2270774
03/16/17 08:54 PM
03/16/17 08:54 PM
Posts: 1,407 northeast ohio
hulmule
northeast ohio
you'll see a lot of these from me as I get ready for a couple of restorations. I'm getting things in order before I start.
Restoring 2- 1979 LIL Red Express trucks 1969 Coronet R/T Convertible.
looking for places to get things done. Chrome work Machine shop work Upholstery Best ways to strip the paint off ? I haven't done a car in years, so I want to make sure I'm sending things off to the right places. Any other services that you guys use that you have had good luck with please let me know. Thanks I live in Painesville Ohio but willing to travel for things or ship.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: Restoration services - Machine shp,Chrome, upholstery etc.
[Re: hulmule]
#2270788
03/16/17 09:29 PM
03/16/17 09:29 PM
Posts: 20,765 A collage of whims
topside
A collage of whims
The quality you want and the budget you have are hugely important to an answer. Best chrome plating I've ever experienced was Ogden Chrome (Ogden, UT): it's expensive, but flawless, about a 2-month timeframe. Machine shop, I've usually found a Mopar specialist or race-engine guy not too far from me; that said, I did have a highly-regarded guy in SoCal build me one great $7500 engine and years later one $10,000 grenade whose post-mortem showed horrible work... Upholstery, should be someone not far from you who does high-end or at least high-quality work; check around at car shows & such. Paint stripping depends on what you have, what you can do yourself...I've had cars dipped, media-blasted, sanded them or chem-stripped them myself... Fasteners & strikers I've sent to Eric Manuel (member 3404): great work, reasonable & timely. He can re-plate latches, but if you want OEM/Mopar Nats-level with the differing finishes, there are a couple guys here whose names I can't recall. Carbs, send to member Scott Smith_Harms for perfection, but I don't know how much $$$. Hope this helps; I'm sure there'll be other answers & souce info as well.
[Re: topside]
#2271402
03/17/17 09:54 PM
03/17/17 09:54 PM
hulmule
northeast ohio
what paint stripping method worked the best for a final product? thanks for your answers. getting all my vendors in place and start with these restorations.
[Re: hulmule]
#2271476
03/17/17 11:53 PM
03/17/17 11:53 PM
topside
A collage of whims
The dip tank method worked best for removing everything on the exterior & interior sides. For a body shell, it's pretty expensive and few guys have big tanks. If you're only doing exterior surfaces, it's kind of a choice between the relative downsides: Media takes a while to blow out of every nook & cranny & crevice, and someone who's not careful might warp a panel depending on what media is used. My paint rep advises against soda (negatively affects adhesion). Chemical paint stripper is nasty, toxic, messy stuff, but the mess is easier using plastic tarps. Mechanical (sanding) is dusty, requires a little care, and some contours (flanges, for example) are difficult to access & strip completely. It's probably the easiest & least expensive to do, though.
