o2 code decipher help #2271407
03/17/17 09:58 PM
03/17/17 09:58 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
My 99 Dakota is throwing a P1197 code
"1/2 O2 sensor slow during catalyst monitor"
Which of the O2s are the culprit?
The "1/2" must mean something, but I can't figure it out.
TIA
Ken
Re: o2 code decipher help [Re: A990] #2271419
03/17/17 10:17 PM
03/17/17 10:17 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
bank 1 sensor behind cat converter.
Re: o2 code decipher help [Re: A990] #2271423
03/17/17 10:24 PM
03/17/17 10:24 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
That sensor has acted up before. I wonder if theres a problem upstream, any way to test a cat?
Re: o2 code decipher help [Re: A990] #2271483
03/18/17 12:16 AM
03/18/17 12:16 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
If you have access to a scanner you would monitor the upstream and downstream o2 sensors Same reading on both would indicate a failed converter. As long as the reading is not max out lean or rich.
Re: o2 code decipher help [Re: A990] #2271505
03/18/17 12:56 AM
03/18/17 12:56 AM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
Salem, I just got a scan tool. Once I get past the setup stage I think I'll log just the o2s. Neat idea! up
