8" converter on the street???
#2270491
03/16/17 12:45 PM
03/16/17 12:45 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Who runs a 8" converter on the street and drives 50-80 mile trips???
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: 8" converter on the street???
[Re: 65 Hemi]
#2270502
03/16/17 01:06 PM
03/16/17 01:06 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
As long as you buy a good quality converter, you won't have any issues at all. I've been running a 9" 5,000 stall on the street since 2003 w/ no trouble at all. Never had a combo that could use an 8".
[Re: 65 Hemi]
#2270506
03/16/17 01:11 PM
03/16/17 01:11 PM
Thumperdart
State of confusion
15+ years so far and never even freshened or adjusted.............CONTINENTAL 5500+...........
[Re: Thumperdart]
#2270514
03/16/17 01:26 PM
03/16/17 01:26 PM
Posts: 1,030 ohio
67mprfan
ohio
15+ years so far and never even freshened or adjusted.............CONTINENTAL 5500+........... Just saying that might be the 5.9x your looking for
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 65 Hemi]
#2270550
03/16/17 02:28 PM
03/16/17 02:28 PM
65 Hemi
San Diego CA
Thanks for all the input. I have run an 8" for a few years but never drove the car more than 25 miles before stopping for a few hrs. Now I want to go 50-60 miles.👍🏻👍🏻👍🏻
Doug
[Re: 65 Hemi]
#2270554
03/16/17 02:31 PM
03/16/17 02:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just have a good cooler.. you might want to run a temp gauge on the trans so you cant watch the temp for a while
[Re: Dave Hall]
#2270614
03/16/17 04:26 PM
03/16/17 04:26 PM
Posts: 43,272 Bend,OR USA
Cab_Burge
I've ran several different 8 and 9 inch good brand converters on the street with no issues at light throttle crusing They will break away and rev up under harder throttle action but seem to stay lock up at light throttle very well I have had two bad 8 inch converters, a older (1975 era) Art Carr and a GER Neither one of them was worth owning
[Re: 65 Hemi]
#2270864
03/16/17 11:20 PM
03/16/17 11:20 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I have an 8" Turbo Action 4500 converter in my car. It has seen 5 drag weeks and is about 16 years old. I do not run a temp gauge, and going down the highway on drag week the car is about 4100lbs with two occupants and cargo. I haven't changed the fluid in a very very long time and it still looks and smells fine. I am sure it could use a freshen up soon because it does drain back when the car sits for a week or so but it is still performing well, I got a new best 60ft last weekend.
There is guys on drag week that run 6000+RPM converters and pull a trailer. I worry about mine a lot less after seeing some of that going on.
68 Barracuda Formula S 340
[Re: 65 Hemi]
#2270972
03/17/17 03:04 AM
03/17/17 03:04 AM
Posts: 506 Utah, USA
1964superstock
Utah, USA
Buy a good 8 inch, you will be glad you did. I have a "tight" 8" 4800 stall A-1 converter that Dave Smith from Pro Trans spec'd out for me with A-1. Absolutely love it, drives like a modern car at part throttle (no noticeable slip or slushy feel), then when you punch it, the engine immediately flashes right to 4800 rpm, and your moving! It was not cheap, but works beautifully. I have the biggest B&M trans cooler you can get. I remember Dave telling me it is a bunch of BS that people think you can't run a 8 inch converter on the street. His answer was, do you want a fast car or not? If you do, run a 8 inch and be done with it. A tight 8 inch is much more efficient than a loose 9.5 inch. My combo: 4:10 Dana 60, full manual pro trans 727, 505 max wedge stroker, 620 HP, 620 tq, 4000 lbs with driver. All street driving so far, very fun.
