Carb advice
#2270487
03/16/17 12:36 PM
03/16/17 12:36 PM
Posts: 1,324 Ohio
jlatessa
Ohio
Getting close to dynoing a new 512 build, have a used ProForm 950 w/1.750" throttle bores with the following specs:
30cc pump pri. white cam, #1 hole 50cc pump sec. brown cam, #1 hole #76 jets pri. #85 jets sec. IABs, #32 inboard, #71 outboard pri. & sec. .110" holes in each butterfly #40 squirters, pri. #35 squirters, sec. downleg boosters
Engine specs: 512 RB 10.7 CR Victor heads, MW Bullet cam; 290/295 @ .20 Part #503000 .651 gross lift separation 110* timing events @ .50; Intake, 22.5-54.5 Exhaust, 66-18 106* centerline 1.5 rockers Indy dual plane MW
4 speed, 3.54 gear, 3900# car
Need to know if the carb is going to be close to what's needed or if I should make some preliminary changes to be closer and maybe save some dyno time.
This is for a mainly street application, Thanks to the experts in advance,
Joe
P.S. I am using a 1" blended spacer for acc. pump clearance
Re: Carb advice
[Re: jlatessa]
#2270530
03/16/17 01:57 PM
03/16/17 01:57 PM
Thumperdart
State of confusion
Joe
P.S. I am using a 1" blended spacer for acc. pump clearance What emulsion package as in how many and what sizes........
Re: Carb advice
[Re: jlatessa]
#2270752
03/16/17 08:11 PM
03/16/17 08:11 PM
Thumperdart
State of confusion
Are the gaskets brown(real old) or the blues...........they can be a bear and a razor knife in the gaskets, some fluid and gentle prying should get em apart......
Re: Carb advice
[Re: PorkyPig]
#2271069
03/17/17 11:33 AM
03/17/17 11:33 AM
Posts: 1,324 Ohio
jlatessa
Ohio
Porky: I bought it from a member here who had it on similar set-up and thought it would perform well as-is. Have not run it though.
Thumper: Was able to coax the metering blocks off this AM, here's what I found;
Primary: 6.5 Power valve #33 orifices at top of idle feed channels Inboard channels w/4 threaded openings have a plug second from bottom.
Scondary: Same as primary with exception of P.V., of course
The metering blocks are purple anodized Al. with no I.D. I could see.
Thanks, Joe
Re: Carb advice
[Re: jlatessa]
#2271070
03/17/17 11:39 AM
03/17/17 11:39 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Good job! I'll remove most of the now irrelevent suggestions I posted and add the following instead. It will be easier to tune in after changing the IFR location. This recent thread covers it well starting about 2/3 down the first page https://board.moparts.org/ubbthreads/ubbt...tml#Post2260468The threaded holes in the vertical channel are for air bleeds into the main well. Almost everyone calls them emulsion bleeds (e-bleeds). Very likely will want to plug another one. It's helpful to take a pencil or marker across from the fuel level site window to note on the block the normal hight of fuel relative to those holes. Holley Carb Passage & Restriction Location & Identification A little WD40 is OK for killing the sticky on the gaskets before assembly.
Re: Carb advice
[Re: jlatessa]
#2271103
03/17/17 12:33 PM
03/17/17 12:33 PM
Posts: 1,324 Ohio
jlatessa
Ohio
Good reading! I guess the low position for IFR is now the consensus. Is this an easy mod or should I have Thumper do mine? Or are they available for my application cheaper?
I can measure my intended fuel level (slightly above hole?) and see where it falls on the metering block, but what am I accomplishing by blocking another orifice?
Bear with me, I've had my nose in engines longer than some of you have been alive, but a lot of this is new to me.
Joe
Re: Carb advice
[Re: jlatessa]
#2271225
03/17/17 03:59 PM
03/17/17 03:59 PM
Mattax
Phila. Pa.
I guess the low position for IFR is now the consensus. I prefer to think of it as physics. Fluid dynamics are complicated enough to begin with. IMO there needs to be a darn good reason to make it more complicated. Most of the time, there isn't. I can measure my intended fuel level (slightly above hole?) and see where it falls on the metering block, but what am I accomplishing by blocking another orifice? Usually the new style bowls have a big clear window, and they use the center of the window as the fuel level. Classic Holley's use a threaded plug clear or brass. Those always use the bottom of the hole as the normal fuel level. Second part - short answer is that when there is too much air bled into the main channel the tiny bubbles have a tendency to join together into big ones. When that happens fuel doesn't flow consistantly. Many of the new carbs have a combination of too many or too large bleeds resulting in inconsistant most of the time. Long Explanation at RFS: Emulsion Tuning Short Example: http://racingfuelsystems.myfunforum.org/viewtopic.php?f=25&t=578
