Removable front clip #2269518
03/14/17 07:03 PM
03/14/17 07:03 PM
Metro Detroit
OUTLAWD Offline OP
OUTLAWD  Offline OP
Metro Detroit
Hi all, I'm looking for some pics/ideas for a removeable front clip with factory front frame rails. Just looking for ideas in how to tie it all together and how to attach it to the frame stubs. Will have strut bars and removable inner fenders. Will be using factory fenders for now, may go to a glass clip as some point.
Thanks in advance!
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Removable front clip [Re: OUTLAWD] #2269533
03/14/17 07:27 PM
03/14/17 07:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I used the tubes for the front end on the
race car... all stock steel parts but I used
zues fasteners at the rear lower fender points
so I could get the front end off in about 3 min.
with help(so it wouldnt flex)... I didnt do any
of that on the Rampage.. I can pull the engine and
trans all in one shot with the front end on it
EDIT
I cant find a pic of the tubes used that mount the
front end but I bought a kit from S&W for doing
this(a pair of tubes that slid in the rails
EDIT
the one thing I did on both cars was the mount
for the radiator.. I used rubber at the bottom
like a C for the lower and a alum rod to hold
it out in location.. works well
wave
Re: Removable front clip [Re: OUTLAWD] #2269554
03/14/17 08:22 PM
03/14/17 08:22 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Here's some pics of how we do ours.....
Pins on the fender bottoms are the olny thing holding clip on once hood is removed..
1 inch square tube slides into 1 1/2 square tube like hitch recievers along side firewall....bottoms of fenders use hood pins on tabs wedled to tops of rocker panel.
Re: Removable front clip [Re: OUTLAWD] #2269556
03/14/17 08:24 PM
03/14/17 08:24 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
My Dart actualy uses factor bumper brackets...I slotted out the factory holes larger to make one long slot. I then used longer bumper bolts with EMT conduit for rollers'Adjustable spacers...I then used a large washer at the end to keep side movement to a minimum.
Re: Removable front clip [Re: OUTLAWD] #2269617
03/14/17 10:15 PM
03/14/17 10:15 PM
Metro Detroit
OUTLAWD Offline OP
OUTLAWD  Offline OP
Metro Detroit
Thanks guys, I am tired of leaning over the fender anytime I am under the hood, and I'm hoping to trim some fat in the process.
Was thinking to use the bumper bolts in a similar fashion, Chassisman
Mr.P, I recall a while back you mentioned longer travel "street friendly" struts for the rampage, did you ever end up swapping them out, if so which ones did you go with? A street car in MI might need more travel than a typical drag strut would offer. I have entertained adapting fox body struts, but need to do more homework.
Re: Removable front clip [Re: Chassisman] #2269622
03/14/17 10:21 PM
03/14/17 10:21 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Mine may be a little different than what your looking for...I needed mine to be able to get out of the way easily and without any help. For that reason I decided to go flip nose.
I wasn't worried about weight so I used a pair of leaf spring sliders mounted to my new frame rails. I made a bracket from the original rail down to the pivot point. Mine is set up to slide forward 4" to get the fenders to clear the doors and then flip forward.
The original frame ends, bumper and mounts, filler panel, grill, fenders and hood will be all tied together as one piece.
I don't have all the bugs worked out yet as it is a work in progress.
Plans at the rear were to use a 1/2" solid round bar welded to the front clip and have it land in a piece of 3/4" steering shaft welded to the body with one end open and notched back to allow the round bar to land on it.
Mind you this is all still primitive and hasn't had any details worked out...
...FAFO...
Re: Removable front clip [Re: OUTLAWD] #2269623
03/14/17 10:22 PM
03/14/17 10:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I havent looked at the car for 2 months..
I just got back from vacation(2 months in
Port A Texas).. I dont know if I will change
the front end
wave
Re: Removable front clip [Re: OUTLAWD] #2269626
03/14/17 10:24 PM
03/14/17 10:24 PM
Not trying to hijack this thread BUT do any of you know about a kit for a tilt one piece front end that slides forward a little to tilt the front end? help
Thanks in advance bow
Re: Removable front clip [Re: Cab_Burge] #2269631
03/14/17 10:29 PM
03/14/17 10:29 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
popcorn
...FAFO...
Re: Removable front clip [Re: OUTLAWD] #2269660
03/14/17 11:19 PM
03/14/17 11:19 PM
Metro Detroit
OUTLAWD Offline OP
OUTLAWD  Offline OP
Metro Detroit
Thanks skicker. Having the option to tilt would be convenient, as I am mostly a 1 man show. Thanks for the pics
Re: Removable front clip [Re: OUTLAWD] #2269714
03/15/17 12:23 AM
03/15/17 12:23 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Mine is simple
Re: Removable front clip [Re: FastmOp] #2269729
03/15/17 12:44 AM
03/15/17 12:44 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Although mine isn't a stock frontend the mods could easily be done and I will probably be doing this to my other 2 Dusters because it makes the car so easy to work on. 4 bolts and its off or on.
I am a one man team to so I made a jig in my car trailer so I could remove and install by myself. The fenders are steel with a fiberglass bumper.
4 pieces of 3/4 black iron pipe and (2) 3/4 pipe collars.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Removable front clip [Re: OUTLAWD] #2269879
03/15/17 11:20 AM
03/15/17 11:20 AM
Metro Detroit
OUTLAWD Offline OP
OUTLAWD  Offline OP
Metro Detroit
Thanks guys.
This guy goes a bit over the top, but if you can get over the cheeky humor he does some nice work.
https://www.youtube.com/watch?v=n_H8bK8o3UM
minute 15 he starts messing with the front end.
Re: Removable front clip [Re: OUTLAWD] #2270150
03/15/17 07:56 PM
03/15/17 07:56 PM
Parts unknown
590 Challenger Offline
Parts unknown
If you are still looking for ideas, here is what I did. I bolted the fenders to square 1 inch tubing, welded some square pegs on the fire wall. Bolted the front to the top of the radiator support, (everything bolted to it already) made a loop with to pins to slide it on to. Solid as can be, oh and little tubes mount to my bumper with pins, comes right off
Re: Removable front clip [Re: 590 Challenger] #2270192
03/15/17 09:06 PM
03/15/17 09:06 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have never thought about doing that, but there is a guy in my town that comes to our show with his Duster and he drives it in the gate and I have been on the road with him
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Removable front clip [Re: Polarapete] #2270413
03/16/17 08:33 AM
03/16/17 08:33 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my front clip is made from kevlar so its a lot more rigid. we only have 6 mounting points but thats all it needs for a solid mount. being Kevlar its real light compared to glass. the front mounts are off the radiator support, the rear are on the top edge of the firewall & we have one each side on the bottom of the fender.
2014-07-18 21.01.05.jpg522045_10150839270345011_584320010_12201592_387220397_n.jpg1546079_216390558548885_485885059_n.jpg
Re: Removable front clip [Re: Polarapete] #2270433
03/16/17 10:20 AM
03/16/17 10:20 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
Any idea what spoiler that is? Camaro?
