Re: Cam bearing tool, which one?
[Re: RV2]
#2268972
03/13/17 10:47 PM
03/13/17 10:47 PM
Posts: 494 IL
EchoSixMike
IL
Lisle is good tool, BHJ is for when you need to install roller cam bearings. S/F....Ken M
[Re: RV2]
#2268990
03/13/17 11:07 PM
03/13/17 11:07 PM
Challenger 1
Cincinnati, Ohio
I'm in the market for a cam bearing tool, I'd like to purchase a quality piece. What's recommended? What should I stay away from? Thanks A snap On one is better than the Lisle tool. I have both, the snap on one uses O rings and the lisle uses rubber sleeves. O rings are better and easier to work with IMO. Plus the snap on one seems harder more solid when you hit it with a BFH.
[Re: cl440]
#2269095
03/14/17 01:20 AM
03/14/17 01:20 AM
RapidRobert
that is what I bought (was on sale somewhere online at the time) as they wanted over a hundred (iirc) whay back when I got a quote to do em locally at a shop. just take your time with it & OT I reclock the bearings with a new 1/16 hole drilled on the bench which is PLENTY for cam bearings & 1/8 on the ones that feed the heads tho I feed the heads externally so I do all (5) of em at .0625"
[Re: B5 Bee]
#2269124
03/14/17 02:08 AM
03/14/17 02:08 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought the Lisle listed above from Summit years ago. Pretty sure the was in the last order that I placed where you could get both the Pro-Shop discount and a 10% off coupon. Ohhhhh the good old days.
[Re: RV2]
#2269531
03/14/17 07:26 PM
03/14/17 07:26 PM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
A long time ago I got a good deal on a second hand Snap-On, it seems like a good one.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2269635
03/14/17 10:31 PM
03/14/17 10:31 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
I bought mine(Lisle) from a Cornwell tool truck years ago, works good, last long time I had to replace several of the sleeves in the last two years, I bought them from Cmp Cams tool company, probably made by Lisle
[Re: Challenger 1]
#2269917
03/15/17 12:18 PM
03/15/17 12:18 PM
Posts: 2,495 Oregon City, OR
Baxter61
Oregon City, OR
I'm in the market for a cam bearing tool, I'd like to purchase a quality piece. What's recommended? What should I stay away from? Thanks A snap On one is better than the Lisle tool. I have both, the snap on one uses O rings and the lisle uses rubber sleeves. O rings are better and easier to work with IMO. Plus the snap on one seems harder more solid when you hit with a BFH. is this the one you have Challenger? https://store.snapon.com/Camshaft-Cranks...t--P635905.aspx
[Re: Baxter61]
#2269925
03/15/17 12:35 PM
03/15/17 12:35 PM
Challenger 1
Cincinnati, Ohio
I'm in the market for a cam bearing tool, I'd like to purchase a quality piece. What's recommended? What should I stay away from? Thanks A snap On one is better than the Lisle tool. I have both, the snap on one uses O rings and the lisle uses rubber sleeves. O rings are better and easier to work with IMO. Plus the snap on one seems harder more solid when you hit with a BFH. is this the one you have Challenger? https://store.snapon.com/Camshaft-Cranks...t--P635905.aspx No I don't think so...that one is a blue point brand and appears to use rubber sleeves. I bet it is the lisle made one. Not that it is a bad or a cheap tool. Like said above it works just fine. Maybe they don't make one with o rings anymore? My snap on one has to be at least 25 years old now. I just looked at it close, still have the directions with it. It don't say who made it that I see.
[Re: Challenger 1]
#2269939
03/15/17 01:05 PM
03/15/17 01:05 PM
Baxter61
Oregon City, OR
I'm in the market for a cam bearing tool, I'd like to purchase a quality piece. What's recommended? What should I stay away from? Thanks A snap On one is better than the Lisle tool. I have both, the snap on one uses O rings and the lisle uses rubber sleeves. O rings are better and easier to work with IMO. Plus the snap on one seems harder more solid when you hit with a BFH. is this the one you have Challenger? https://store.snapon.com/Camshaft-Cranks...t--P635905.aspx No I don't think so...that one is a blue point brand and appears to use rubber sleeves. I bet it is the lisle made one. Not that it is a bad or a cheap tool. Like said above it works just fine. Maybe they don't make one with o rings anymore? My snap on one has to be at least 25 years old now. I just looked at it close, still have the directions with it. It don't say who made it that I see. didnt think so, Im curious to see/find one like yours. I need to buy one myself and Im sure the Lisle ones work just fine and get 1000's of bearings installed everyday, just would like to see the Snap-On one too.
[Re: Challenger 1]
#2270143
03/15/17 07:34 PM
03/15/17 07:34 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
The lisle tool I had came with extra rubber sleeves. The snap on tool uses o rings instead and I have never wore one out. Much easier using the snap on tool because the bearings do not catch on the o rings and slide on and off better and you can tell if the expanders are lined up correctly before using it with o rings instead of sleeves.
They're all probably from the same manufacturer.
