Re: Predator heads
[Re: boatracer572]
#2273011
03/20/17 02:31 PM
03/20/17 02:31 PM
KOS
[quote=dthemi]The predator made for hemi blocks is a better place to start. The wedge requires a removable plug in the intake port. Seriously limiting what you can do with the head. Also the 600 head isn't as good. A nice head for sure, but it is what it is. You can exceed indy's claims for power if you're willing to spend what it takes to do it. As soon as i can get another +.500 deck block Ill be building a 1400hp na predator. OK how much hp are you leaving on the table using a wedge block?
Re: Predator heads
[Re: dthemi]
#2273213
03/20/17 07:35 PM
03/20/17 07:35 PM
Posts: 31,050 Oregon
AndyF
The predator made for hemi blocks is a better place to start. The wedge requires a removable plug in the intake port. Seriously limiting what you can do with the head. Also the 600 head isn't as good. A nice head for sure, but it is what it is. You can exceed indy's claims for power if you're willing to spend what it takes to do it. As soon as i can get another +.500 deck block Ill be building a 1400hp na predator. KB should have blocks in stock shortly. Not sure about a raised deck block though but I think they'll have raised cam blocks for sure.
Re: Predator heads
[Re: slick526]
#2273215
03/20/17 07:36 PM
03/20/17 07:36 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
From my understanding KB will be making 4 blocks. Hemi std cam and raised, Wedge std cam and raised. Sounds like no plans to do anything else other than getting to work on the Gen III program.
I was just poking on the 200hp comment. Darren is correct the plug in the port will limit what could be done to the port at a cost is no object scenario. For most of us I don't think there will be a ton of difference ultimately. I believe Jason Digby's is a Wedge deal and it does ok.
Re: Predator heads
[Re: slick526]
#2274139
03/22/17 10:30 AM
03/22/17 10:30 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Can't say exactly how much different it is between them. Just that it can't be made as thin up there, and the hole adds to destabilizing the valve train. Then having something shaped like that, and that thin threaded into the port is going to leak, and crack eventually. When you have to mow a hole all the way through, top to bottom, then plug off the top, why expose yourself to all the potential problems if you're starting from scratch? Starting with a wedge block, i'd still take the preds over the 600.
As for blocks, no one is going to do it for a while as I understand it. AJPE says they may be in the mopar block business soon, so maybe. I can take a standard deck, and plate it up, but then I'm still stuck with 48 degree lifter angles. A .5 up deck with 45 degree lifters really helps, and I don't want to do it any other way.
I thought Digby's stuff was forced induction.
When the summer is over, if blocks aren't available I may just redo the one I have as an NA. More stroke, +.03 bore, more valve, an NA cam, more compression, thinner rings with 20 pounds less tension, lighter piston, and pins, lighter rods, way way more port volume, shorter runner manifold, big bore carbs, take the nitrous taper out of the quench, correct the lifter galley oil waste, and get serious about weening it off oil. Not having to contend with the nitrous will make it reasonable to drop the pressure in half.
I've swapped my car from a 2 to a 3 speed, so the motor could stand to be more peaky now.
Re: Predator heads
[Re: dthemi]
#2274162
03/22/17 11:50 AM
03/22/17 11:50 AM
KOS
I've swapped my car from a 2 to a 3 speed, so the motor could stand to be more peaky now. thx for the clarification....so only one hole in one port?im trying to visualize it but not familiar with preds at all any pix?
Re: Predator heads
[Re: slick526]
#2274309
03/22/17 04:23 PM
03/22/17 04:23 PM
Al_Alguire
Las Vegas
Mine are Wedge heads, and as stated I believe Jasons is as well. At any rate yes there is a plug to deal with in the port. We have not had any issues with it. They are numbered so we know where they go and have had them out a few times. You have to in order to bolt the heads on. I run 1300+ open pressure and so far so good. But not a ton of run time on it yet.
Re: Predator heads
[Re: Al_Alguire]
#2274416
03/22/17 07:50 PM
03/22/17 07:50 PM
KOS
Mine are Wedge heads, and as stated I believe Jasons is as well. At any rate yes there is a plug to deal with in the port. We have not had any issues with it. They are numbered so we know where they go and have had them out a few times. You have to in order to bolt the heads on. I run 1300+ open pressure and so far so good. But not a ton of run time on it yet. Well Al thats pretty reasurring and i thought Jasons where as well and i imagine his spex are pretty stout also so i guess time will tell.im in no rush got bigger fish to fry right now but i always keep my eyes open for deals and didnt want to regret buying the wedge version.keep us posted if any issues arise.thx
Re: Predator heads
[Re: slick526]
#2274811
03/23/17 02:48 PM
03/23/17 02:48 PM
Posts: 200 AB
Efidart
AB
Indy fixed the cracking problem when they bought the predator heads from Steve Gill. Those are the first type run off of Deans Cuda.
The new revision that Indy sells has that problem fixed and are almost trouble free.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
