Assume a valiant is the same.
Years ago I replaced the factory lines with a hodge podge of stuff (parts store lines, 67' a-body lines, etc...).
I have a set from inline tube, and nothing appears to make any since (sp?), I am using their dual master cyl conversion kit, which claims to use all the "factory" locations, but nothing adds up.
Does anyone have pics of a factory setup (ideally without the engine)? - did some google image searches, found some help, but not quite the angle I need - looking at the lines from the prop valve in the front. Also, looking for a good pic of the front L/R line to see how it routes (with col shift).
Thanks!
