Re: Indy fuel injection setup?
[Re: PolyDart]
#2268088
03/12/17 04:16 PM
03/12/17 04:16 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I have an Indy W2 intake that was cut for fuel injectors. The work looks nice but they did not come with rails.
The manifold was bought Through Ryan Johnson at Shady dell, so I am not %100 sure if the manifold came from indy cut for injectors of if he did it.
I have a tunnel ram I am wanting to convert to EFI and Indy was one of the companies I emailed asking about doing it. It has been over a week and they had not responded.
68 Barracuda Formula S 340
[Re: PolyDart]
#2268621
03/13/17 02:36 PM
03/13/17 02:36 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Mechanical fuel injection? I have an Indy 8-Stack system, fits Max Wedge ports, has been ported, has the split shafts, Enderly pump, Kinsler Hi-speed, tune up for both a 408 Cu. In and a 528 cu.in. engine. Very easy system to use.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#2269165
03/14/17 05:38 AM
03/14/17 05:38 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Mechanical fuel injection? I have an Indy 8-Stack system, fits Max Wedge ports, has been ported, has the split shafts, Enderly pump, Kinsler Hi-speed, tune up for both a 408 Cu. In and a 528 cu.in. engine. Very easy system to use. Nice, got any pics of the 528 with stacks ?
1963 Plymouth Max Wedge 1971 Barracuda
