Spray undercoating #2267323
03/11/17 12:23 PM
03/11/17 12:23 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ok, getting ready to undercoat one.
I'm using the 3m brand with a Schultz gun. Sprayed it at about 40 psi. My issue is its a stringy mess. It looks like cobwebs in the inner fender ,,,not happy.
Any recommendations of either a different product you've used or am I doing something wrong. I think I used this same stuff back when I did my challenger and I dont remember having this problem then . I'm not against using the can stuff either if its thick.
This isn't a concourse resto, but Im trying to look something like OE if I can
Re: Spray undercoating [Re: gtx6970] #2267353
03/11/17 01:09 PM
03/11/17 01:09 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Use resto ricks undercoating... I find it takes mulitple coats to look like factory, but sprays nice.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Spray undercoating [Re: gtx6970] #2267389
03/11/17 01:56 PM
03/11/17 01:56 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I've used both Resto Rick's stuff and 3M - never saw stringing. I wonder if your product separated.
Re: Spray undercoating [Re: gtx6970] #2267450
03/11/17 03:28 PM
03/11/17 03:28 PM
eastern,Ky
70RT Charger Offline
eastern,Ky
I'd use Ricks if going original. I've used the 3m stuff and didn't like. My last car I sprayed Bedliner because it's going to be a driver and I love it.
Re: Spray undercoating [Re: 70RT Charger] #2267458
03/11/17 03:41 PM
03/11/17 03:41 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
This car is very much going to get driven, a lot and hard.
Mind if I ask what brand bed liner materiel you used? Is it shiny or pretty dull looking ? A buddy of mine who does painting advise this very idea, and right now I'm leaning that way pretty hard
I want it protected and if I can get reasonably close to the texture it has when new ,,, The cars owner and I'm good with that.
I asked someone else who had use the Resto Rick stuff and sounds like he had a similar experience that I did , especially the mess part.
Re: Spray undercoating [Re: gtx6970] #2267465
03/11/17 03:55 PM
03/11/17 03:55 PM
Mass
charge70 Offline
charge70  Offline
Mass
Try dropping the air pressure down.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Spray undercoating [Re: gtx6970] #2267540
03/11/17 05:55 PM
03/11/17 05:55 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
I just did a job with Resto Ricks stuff and I thought it sprayed out nice. I used a plastic can that did not like Ricks stuff so I'll have to find another gun setup. It dries hard and will not rubb off. I did a job with the 3 m stuff years ago and it did not ever get hard enough for my taste.
Re: Spray undercoating [Re: 70RT Charger] #2267706
03/11/17 10:49 PM
03/11/17 10:49 PM
eastern,Ky
eastern,Ky
I'd say it's like a semi-gloss? I used Herculiner and sprayed it with an undercoating gun I'm thinking around 50 psi. You'll have to play with the psi to see what works good for you and it takes 2 good coats to cover but don't spray to thick or it will run just like anything else. Just make sure to stir it good. This Herculiner has an aggressive texture also it but I like it. Now if your looking for something with a little smoother texture and you can also add paint to it and change colors it is called Hippoliner. I sprayed my truck bed with it and this stuff is also pretty dang sweet and it's harder than a whores heart. I don't have good enough service to download the pics tonight of it.
Re: Spray undercoating [Re: charge70] #2267721
03/11/17 11:02 PM
03/11/17 11:02 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Bill, I used 3M for some touch ups and was happy. I think I used 30-35 psi and was at 12 inchs away
I always go with Resto Ricks when needed
Good Look.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Spray undercoating [Re: gtx6970] #2267722
03/11/17 11:02 PM
03/11/17 11:02 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Bed liner is fine if your going to keep the car... go to sell it and it looks like its covering up stuff a lot more than undercoating. I've done it before... if the prep isn't really good, be prepared for it to fall off in chunks/crack etc. Undercoat sticks a lot better and flexes better.
Re: Spray undercoating [Re: gtx6970] #2267768
03/12/17 12:12 AM
03/12/17 12:12 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
x2 on trying to vary the pressure.
I used UPOL Raptorliner Bedliner, very good stuff to work with and lays down very nice. Rock hard surface.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Spray undercoating [Re: gtx6970] #2267839
03/12/17 02:19 AM
03/12/17 02:19 AM
KY
65pacecar Offline
65pacecar  Offline
KY
I use Wurth Undercoating some, sprays great and closest to original out of a spray can. Resto Ricks stuff if shooting from a gun.
Re: Spray undercoating [Re: GoodysGotaCuda] #2267869
03/12/17 05:23 AM
03/12/17 05:23 AM
eastern,Ky
eastern,Ky
That looks good.
Re: Spray undercoating [Re: Silver70] #2267872
03/12/17 05:34 AM
03/12/17 05:34 AM
eastern,Ky
eastern,Ky
[quote=Silver70]I've done it a lot! There is so much wrong with this post right here it ain't funny. I scraped the factory undercoating off of my car and torched some of it off. Believe me if anything is going to hide anything it's factory undercoating and Bedliner sticks as good and will not crack and it does flex. Bedliner will show more than undercoating and you just can't gob it on and cover up $hit like your letting on.
Re: Spray undercoating [Re: 70RT Charger] #2268021
03/12/17 02:36 PM
03/12/17 02:36 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
[quote=Silver70]Bed liner is fine if your going to keep the car... go to sell it and it looks like its covering up stuff a lot more than undercoating. I've done it before... if the prep isn't really good, be prepared for it to fall off in chunks/crack etc. Undercoat sticks a lot better and flexes better.
You must be using spray can bedliner if you think it's thinner than undercoat per coat. Good bedliner is like 3 times as thick if not more per coat. Like I said, you want to hide stuff, use bedliner. I've used both at least 20 times and good resto rick undercoating looks so much better. I used to think the same as you, but not after the last car, never again... it's good for a truck bed and that's it. Bedliner looks like plastic, just looks out of place on a muscle car.
Re: Spray undercoating [Re: gtx6970] #2268118
03/12/17 05:09 PM
03/12/17 05:09 PM
Mass
charge70 Offline
charge70  Offline
Mass
Has anyone tried baseing with bedliner and top coating with Resto Ricks undercoat?
Re: Spray undercoating [Re: gtx6970] #2268751
03/13/17 06:07 PM
03/13/17 06:07 PM
Chicago
PurpleBeeper Offline
Chicago
To the original poster... If you're getting cob webs, then the solvent in the paint isn't all that compatible with the paint itself and/or is evaporating too quickly. Many companies have swapped out "good" solvent and replaced it with acetone (not a very good paint solvent & evaporates fast, but gets around various states' "VOC" regulations).
You can put the gun closer (less time for solvent to evaporate), turn air pressure down as others have suggested, or maybe thin the paint with a slower solvent ("summer blend" if you have that option).
Bedliners are usually either polyurethane or polyuria. Polyurethane dries slower & is more flexible. Polyurea dries in 15 seconds and is more brittle. There are also some polyurethane/polyuria hybrids out there.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Spray undercoating [Re: gtx6970] #2269188
03/14/17 09:38 AM
03/14/17 09:38 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks for the comments.
I'm going over this week to talk to my local paint rep and see what he suggests . Maybe I just got a bad jug of material. I think Ive used this same stuff before with excellent results. So we'll see .
Re: Spray undercoating [Re: gtx6970] #2269209
03/14/17 10:34 AM
03/14/17 10:34 AM
P
Porter67 Offline
Porter67  Offline
P
I wonder how some of this stuff would act if a car fire were to happen?
Re: Spray undercoating [Re: gtx6970] #2270085
03/15/17 05:28 PM
03/15/17 05:28 PM
eastern,Ky
eastern,Ky
Before I installed my NOS quarters years I go I sprayed some 3M inside my quarters just to save time from having to do it after I installed them. I had the same result as you. I ended up scraping everybody bit of it off.
