Correct Mirror for 71 'Cuda #2267046
03/10/17 09:29 PM
03/10/17 09:29 PM
Akron, ohio
76orangewagon Offline OP
Akron, ohio
I'm trying to make sure I buy the correct LH mirror for my 1971 Cuda according to the build sheet and could use a little help. The line on the broadcast sheet is blank so I know Dual mirrors are out and I assume that means I just had a plain jane manual mirror, Is the picture of the style correct ?
Re: Correct Mirror for 71 'Cuda [Re: 76orangewagon] #2267139
03/11/17 12:46 AM
03/11/17 12:46 AM
BS23H1B Offline
BS23H1B  Offline
This might help
Re: Correct Mirror for 71 'Cuda [Re: 76orangewagon] #2267232
03/11/17 04:29 AM
03/11/17 04:29 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Yep, that's it.
Re: Correct Mirror for 71 'Cuda [Re: 76orangewagon] #2267310
03/11/17 12:03 PM
03/11/17 12:03 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
my71 barracuda conv. had 1 sport mirror on left side i'm sure had not been touched as this was in 82 bought off original owner
Re: Correct Mirror for 71 'Cuda [Re: 76orangewagon] #2267398
03/11/17 02:07 PM
03/11/17 02:07 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Non remote mirror. I do believe that 70 and 71 are different.
Re: Correct Mirror for 71 'Cuda [Re: 76orangewagon] #2267420
03/11/17 02:34 PM
03/11/17 02:34 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
So are the 70 and 71 E body plain jane mirrors different? Is it the bases?
Also those mirroe gaskets obviously are different than the rally mirror gaskets. Were they an E body only mirror gasket or were they used on other years/models?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Correct Mirror for 71 'Cuda [Re: 71TA] #2267423
03/11/17 02:39 PM
03/11/17 02:39 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
That's correct Jim, 70 is different from 71, 70 had a shorter base.
Re: Correct Mirror for 71 'Cuda [Re: 76orangewagon] #2267424
03/11/17 02:42 PM
03/11/17 02:42 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Thanks Mike. So they probably used the same screw holes but the gaskets are obviously different than the rallye mirrors. I need to get one of each of an original non remote mirror and gasket from a 70 and 71-4 to make the gaskets for my gasket sets.
Re: Correct Mirror for 71 'Cuda [Re: 76orangewagon] #2267931
03/12/17 12:00 PM
03/12/17 12:00 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Besides the base , the mirror head on a 70 is more oval then round like a 71
Re: Correct Mirror for 71 'Cuda [Re: 76orangewagon] #2267938
03/12/17 12:09 PM
03/12/17 12:09 PM
Akron, ohio
Akron, ohio
I see that they are specific for individual years (70 only & 71 only) PG Classics has a weekend spring sale and is offering a 30% discount. Looks like I better buy now and save.
