Re: Real world weight loss program and it` cost..........
[Re: Thumperdart]
#2270531
03/16/17 01:58 PM
03/16/17 01:58 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I also need to research oil filters and find one that flows 20 to 25 GPM so I can use only one filter.The dual set up needs to be relocated to fit the "J" bars.
[Re: Thumperdart]
#2270539
03/16/17 02:09 PM
03/16/17 02:09 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
You might want to take another measurement on the width of the k member cut. Make sure it is wide enough to remove the pan bolts front and sides. Don't ask how I know.
[Re: hemi-itis]
#2270579
03/16/17 03:23 PM
03/16/17 03:23 PM
Thumperdart
State of confusion
I also need to research oil filters and find one that flows 20 to 25 GPM so I can use only one filter.The dual set up needs to be relocated to fit the "J" bars. I've seen those dual deals cause more problems than good and do you REALLY need that...............
[Re: hemi-itis]
#2270756
03/16/17 08:18 PM
03/16/17 08:18 PM
Posts: 1,896 Spahn Ranch
RMCHRGR
Spahn Ranch
I also need to research oil filters and find one that flows 20 to 25 GPM so I can use only one filter.The dual set up needs to be relocated to fit the "J" bars. Be interesting to see how much that whole remote setup weighs with all the lines, fittings and oil in it. At a minimum there's at least a few lbs in extra fluid weight with the oil in the lines and those two big a$$ filters.
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#2270857
03/16/17 11:09 PM
03/16/17 11:09 PM
fullmetaljacket
I agree again and thoroughly. I would suggest going lean and clean with that bullet. I'm sure that a lot has come a long way in the scope of oiling systems, fuel hose/coupling systems and such that new materials or the lack of so much equipment can still bring the same or better results to keep it light.
Itis, If you just went with a thin gauge 321 Military grade stainless exhaust system to copy what you have now, you'd save at the very least, 35-40 Lbs or more. When I come over, I'm gonna bring a sample left over from my recent lightweight stainless exhaust system. A little pricey, but man, you gotta start some where with that Sumo Wrestling racer of yours. Less weight, less effort, less breakage in getting to the stripe without a sweat gland opening. If at the very least, try and relocate everything up front towards the rear, even if it's only an inch rearward. The transfer will astound you once the car finds that (Tipping point) sweet spot.
[Re: fullmetaljacket]
#2270992
03/17/17 04:29 AM
03/17/17 04:29 AM
hemi-itis
If not this weekend, this coming week for sure. Life and stuff get in the way,,,,,,,,,
[Re: moparx]
#2271110
03/17/17 12:53 PM
03/17/17 12:53 PM
fullmetaljacket
I didn't know that there were street named signs on Long Island including STOP signs. LOL.
[Re: dvw]
#2271553
03/18/17 02:34 AM
03/18/17 02:34 AM
hemi-itis
Uhm, I never thought of removing the fenders. That's even lighter than aluminum, glass, or even carbon fiber. Doug Doug, will it effect the Aerodynamics of the flying brick?? ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
#2272085
03/19/17 12:21 AM
03/19/17 12:21 AM
hemi-itis
I didnt weight it but it feels like 3 lbs.IT more the upper half above the opening in the bottom of the "K".I was hoping for more,by the time we close it off,,,,,,it will be ZILCH savings.
[Re: Thumperdart]
#2272282
03/19/17 12:42 PM
03/19/17 12:42 PM
hemi-itis
The latest cut in the "K" was just above the opening on the bottom.Looks like I can plate a few inches on the sides and maybe 6 inches on the front.The piece cut out maybe 2 lbs,,,,,
