Re: Differance between 5 and 6 speed manuals (truck)
[Re: TheBlueBeast]
#226604
02/17/09 04:11 AM
02/17/09 04:11 AM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
If you are buying a manual trans truck to actually work, get the 6 speed. The gear splits are lots closer and will keep you in the power band better than a 5 speed. As I'm sure you noticed, 1st and O/D are basically the same. The difference is that in the 6 speed you have 4 gears to get you from 1st to O/D instead of only 3. When my 5 speed trans dies in my 91 Cummins W250, I plan to swap to a 6 speed. I have towed with a friends 6 speed and it is night and day better than my 5 speed. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
[Re: phantomx]
#226605
02/17/09 12:20 PM
02/17/09 12:20 PM
Posts: 6,516 Santa Cruz, California
Lefty
The ratios in my NV5600 are perfect for towing due to the even spacing between all the gears.
[Re: Lefty]
#226606
02/17/09 03:38 PM
02/17/09 03:38 PM
phantomx
W. Sacto CA. USA
Also, before all of the trucks started coming with high output engines as standard (early 04 down) you could only get the 6 behind high output engines. So if you are looking at earlier trucks, a 6 speed will get you a higher power engine. Travis..
