1-7/8 or 2 inch headers for 500cid stroker?
#2265036
03/07/17 06:18 PM
03/07/17 06:18 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
Getting close to finishing up my 440 based 500 stroker build. Max wedge size Trick-Flow heads, Solid cam, single plane intake. I currently have TTI 1-7/8 headers and am trying to decide if it I worth it to upgrade to TTI or Dougs 2 inch headers. I can get sell my old headers to offset some of the cost of new headers. Is it worth changing for a mainly street car?
The only Carbs I care about are under the hood!
Re: 1-7/8 or 2 inch headers for 500cid stroker?
[Re: Azzkikrcuda]
#2265044
03/07/17 06:38 PM
03/07/17 06:38 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
I gonna be the first of I bet many who will say run what ya got
[Re: Azzkikrcuda]
#2265046
03/07/17 06:39 PM
03/07/17 06:39 PM
Posts: 200 Colorado
Bob J
Colorado
I was told to run by Hughes TTI 2 1/8 step headers but that will depend on how much power is in the motor. My motor is around 650HP plus it has dual 3 inch exhaust with X pipe.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: Azzkikrcuda]
#2265058
03/07/17 06:49 PM
03/07/17 06:49 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
You'll be fine with the 1 7/8. I always ran 2" on the race cars but I run 1 3/4 hedman's on my 500" street motor just because they were dirt cheap and I'm not concerned with ET.
[Re: Azzkikrcuda]
#2265060
03/07/17 06:51 PM
03/07/17 06:51 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
for primarily street car I wouldn't bother if looking for all the HP 2"for sure . There was a test done in 1 of the magazines , it seemed the tipping point was 500ci and above was 2" primary . when I went to my 505 I went to Dougs over Hooker 1 7/8 , I want everything I can get , but I also run 3 exhaust to diff". Way easier changing plugs with the Dougs
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Azzkikrcuda]
#2265093
03/07/17 08:00 PM
03/07/17 08:00 PM
fast68plymouth
So. Burlington, Vt.
My prediction......
For the most part, I think it would be something like this:
From around 3-400 rpm above peak TQ and below, the 1-7/8" would be better, then above that the 2" will take over.
How much difference? Not really sure....... I'd guess peak to peak maybe 20-25hp.
On a 715hp 542 it was about 40hp from my dyno headers(2-2 1/8 x4) to his 1-7/8" fenderwells. I've done that same test before on a 670hp 493 and the results were about the same...... Close to 40hp difference.
With the 542, the big headers were on the plus side at 4500rpm, and at 6500rpm they were 55hp better.
[Re: forphorty]
#2265400
03/08/17 03:31 AM
03/08/17 03:31 AM
Posts: 43,308 Bend,OR USA
Cab_Burge
Do you trust a English major to get accurate information on dyno testing? I've seen way to many errors printed in most of the popular automotive magazines like Hot Rod and Car Craft to trust every thing they print 100% O.P., dyno testing gains don't make the car go faster at the track, trust me on that
[Re: Azzkikrcuda]
#2265568
03/08/17 02:04 PM
03/08/17 02:04 PM
Cab_Burge
[Re: Cab_Burge]
#2265693
03/08/17 06:14 PM
03/08/17 06:14 PM
Azzkikrcuda
North Dakota
Lots of varied opinions, But pretty much what I expected. More HP on the top end, Probably won't notice it much on a street car. That being said I think I will go with the 2 inch headers, thanks for all the info.
