relay placement
#2263751
03/05/17 03:46 PM
03/05/17 03:46 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I was reading a article the other day that showed a picture of the owners car interior , It showed a large group of relays nicely wired by the floor shifter. I always thought that the relay should be placed close to the device that it was to activate. Whats the general consensus on this.
Re: relay placement
[Re: Stanton]
#2263886
03/05/17 07:34 PM
03/05/17 07:34 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
If you have 10' of #12 wire total in a circuit it does not matter if the relay is at 1' or 9' the voltage drop will be the same.
The key is to reduce the total wire length while keeping the relays and overcurrent protection in a serviceable location where it will not be damaged
A relay is just a electrically operated switch. They are not magic devices that fix everything. Sorry if this sounds like a rant, but I see guys make a lot of basic wiring mistakes.
"Just a Bracket car dressed up like a streetcar"
Re: relay placement
[Re: rowin4]
#2263946
03/05/17 09:18 PM
03/05/17 09:18 PM
Posts: 26,477 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Judging from new cars and aircraft, it seems that the relays are located in a place that's convenient to group them rather than the distance to source/load.
Re: relay placement
[Re: John_Kunkel]
#2263961
03/05/17 09:41 PM
03/05/17 09:41 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Judging from new cars and aircraft, it seems that the relays are located in a place that's convenient to group them rather than the distance to source/load. Whats nice about this also, Is you can easily supply Big power to one place, to multiple relays and send the current out with correct size wiring to its components and signal them with low amp switches. But also see the advantage of putting a relay in the back near the bat/fuel pump in that situation. IMO, both can be used together to work best for your electrical system. EDIT, just what he said; distance to source/load.
Re: relay placement
[Re: Just-a-dart]
#2264020
03/05/17 11:04 PM
03/05/17 11:04 PM
Posts: 9,973 MI, usa
dvw
MI, usa
A relay is just a electrically operated switch. They are not magic devices that fix everything. Sorry if this sounds like a rant, but I see guys make a lot of basic wiring mistakes. I do not agree with the voltage drop being the same. Acceptable maybe, but not the same per ohms law. That being said why use an extra length of heavier gauge wire than needed? Install the relay near the powered device with the proper gauge necessary to carry the required current. Doug
Re: relay placement
[Re: dvw]
#2264025
03/05/17 11:11 PM
03/05/17 11:11 PM
Posts: 11,702 W. Kentucky
justinp61
W. Kentucky
I do not agree with the voltage drop being the same. Acceptable maybe, but not the same per ohms law. That being said why use an extra length of heavier gauge wire than needed? Install the relay near the powered device with the proper gauge necessary to carry the required current. Doug Can you please explain?
Re: relay placement
[Re: crackedback]
#2264056
03/05/17 11:57 PM
03/05/17 11:57 PM
Sport440
Canton, Ohio
If you place the same amount of current over a 1' run or a 10' run, the voltage at the end of the 10' run will be lower when using the same size wire.
The larger the wire, the less drop you will observe.
This is why all the relay kits I build use 12ga wire. Is it larger than maybe needed, possibly. Will the voltage drop be less than if using 12 or 16ga wire, you bet. In the electrical scheme of things if you use the correct wire size for the amperage. 1 ft, vs 10 ft. is nothing. That's the point that was being made. In the industry of electric your running lengths of a 100 ft plus for 20 amp and higher circuits.
Re: relay placement
[Re: justinp61]
#2264144
03/06/17 02:37 AM
03/06/17 02:37 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I do not agree with the voltage drop being the same. Acceptable maybe, but not the same per ohms law. That being said why use an extra length of heavier gauge wire than needed? Install the relay near the powered device with the proper gauge necessary to carry the required current. Doug Can you please explain? https://youtu.be/vZL0tSnzK_4... I hope this helps...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: relay placement
[Re: rowin4]
#2264161
03/06/17 03:23 AM
03/06/17 03:23 AM
Posts: 7,521 Minnesota
Hemi_Joel
Minnesota
In the original posters scenario, if you put all the relays inside by the shifter, you defeated the whole purpose of using a relay. The purpose of a relay is to reduce the number of heavy gauge connectors and shorten the length of heavy gauge wire, thus reducing voltage loss, plus simplifying the wiring, saving money and reducing weight. They ran the heavy gauge wires within reach of the driver. At that point, just skip the relay and use a 30 amp toggle switch.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: relay placement
[Re: rowin4]
#2264164
03/06/17 03:42 AM
03/06/17 03:42 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I have an arc 8000 switch panel/relay board in the cab of my Dakota, and use the ARC relay to trigger another relay close to the source, fuel pump in the back, fan and water pump up front.... Everything else runs off the arc panel.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
Re: relay placement
[Re: rowin4]
#2264237
03/06/17 12:41 PM
03/06/17 12:41 PM
Posts: 8,079 Tulsa OK
Bad340fish
Tulsa OK
I run a Leash board up front with another 2 relay board at the back for the fuel pumps.
68 Barracuda Formula S 340
Re: relay placement
[Re: rowin4]
#2264417
03/06/17 05:55 PM
03/06/17 05:55 PM
Posts: 12,291 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Less spaghetti if the relays are close to the device. If you have electric fan(s), a water pump and/or other high current components in the front of the car, a single heavy gauge wire ran to a junction or a harness providing high amp power to a group of relays is a cleaner set up. High current 12v can be routed to the individual components from the relays rather than running all of those heavy gauge wires from the interior of the car.
Same with the fuel pump(s). The relay is always near the pump.
