So people keep asking me.... #2263233
03/04/17 02:17 PM
03/04/17 02:17 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
"How much horsepower does that thing have?"
I really have no idea. Didn't have a number in mind when it was built. So I ask the all knowing..what's your guesstimate/WAG?
451 400 block/440 crank
Indy-1's unported
11.4 to 1 static compression
262 .050 duration .620 lift solid roller
Indy 4500 intake with 950 HP
Am I forgetting anything?
Thanks in advance!
Re: So people keep asking me.... [Re: Benforsp] #2263284
03/04/17 03:34 PM
03/04/17 03:34 PM
North Texas
TheTieWrapKid Offline
North Texas
595 hp - 580 ft lbs
Re: So people keep asking me.... [Re: Benforsp] #2263348
03/04/17 05:56 PM
03/04/17 05:56 PM
my own world
theraif Offline
theraif  Offline
my own world
just say it`s faster than cooters hound
Re: So people keep asking me.... [Re: Benforsp] #2263354
03/04/17 06:10 PM
03/04/17 06:10 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Take it to the track and find out.
Mopar to the bone!!!
Re: So people keep asking me.... [Re: Benforsp] #2263367
03/04/17 06:42 PM
03/04/17 06:42 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
625HP
Re: So people keep asking me.... [Re: Benforsp] #2263385
03/04/17 07:33 PM
03/04/17 07:33 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
What's it run and what's it weigh
Re: So people keep asking me.... [Re: Benforsp] #2263423
03/04/17 09:16 PM
03/04/17 09:16 PM
jersey
Spaceman Spiff Offline
jersey
It COULD have 600hp and run 12's. or it COULD have 450hp and run 11's.
Dyno numbers are great, but don't mean much going down the track. Just tell people you never had it dynoed.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: So people keep asking me.... [Re: Spaceman Spiff] #2263470
03/04/17 11:10 PM
03/04/17 11:10 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I'd guess low 600 hp range.
And smile secretively, then wink whistling
Re: So people keep asking me.... [Re: Benforsp] #2263477
03/04/17 11:26 PM
03/04/17 11:26 PM
I will tell some people how much HP the motor in the car made if I have those results and trust the dyno.
I have also said "not enough" more than once whistling work
As already pointed out, any bad component can slow the car down below what other cars run with the same parts and power at the track the same day shruggy
Re: So people keep asking me.... [Re: Benforsp] #2263619
03/05/17 12:51 PM
03/05/17 12:51 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
If you didnt care to dyno it when you built it, then it shouldnt matter now either. If your happy with it, it runs good, then it really doesnt matter. Have fun with it.
RIP Monte Smith
Re: So people keep asking me.... [Re: CompWedgeEngines] #2263645
03/05/17 01:25 PM
03/05/17 01:25 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
I've never taken it to the track so don't have any numbers.
Definitely happy with it...I didn't dyno it because I didn't have a goal HP wise and trying to find time was difficult. I was just curious and don't want to be the guy with stock small block with an intake and headers quoting 700hp 🙄. Anyway, I figured some people on the board may have had a similiar engine setup that they actually took the time to dyno theirs.
Re: So people keep asking me.... [Re: Cab_Burge] #2263715
03/05/17 03:15 PM
03/05/17 03:15 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By Cab_Burge
... "not enough"...
I think I've just seen my new go-to answer.
Re: So people keep asking me.... [Re: Benforsp] #2263721
03/05/17 03:22 PM
03/05/17 03:22 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I suppose you could get it dyno-tested and then you'd know for sure.
Re: So people keep asking me.... [Re: bobby66] #2263758
03/05/17 03:53 PM
03/05/17 03:53 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I usually smile really big and say 325 horsepower. After all, it *is* a four barrel!
Re: So people keep asking me.... [Re: BradH] #2263765
03/05/17 04:03 PM
03/05/17 04:03 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
... "not enough"...
laugh2
72 Plymouth Roadrunner 11.08@123.25
Re: So people keep asking me.... [Re: FastmOp] #2263780
03/05/17 04:29 PM
03/05/17 04:29 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
THIS^^^^^^^^^^^^^^^^^
Will answer that question whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
