I have a 1996 Ram 3500 SLT and I would like to add factory fog lamps. I have figured everything out but the interior wiring. The under hood relays and fuse are in place from the factory as is the wiring under the core support. I was hoping the harness for the switch would be behind the dash but it is not. I have a factory switch with the connector a few inches of harness. I was trying to figure out if there was a point where the dash harness connects to the under hood harness that I can tap into to connect the switch.
