Page 4 of 4 1 2 3 4
Re: Car lift for your shop [Re: JMCFAN] #2262303
03/02/17 08:02 PM
03/02/17 08:02 PM
Missoula, Montana
ChadP Offline
ChadP  Offline
Missoula, Montana
Several of us in Missoula have bought the 8000 from the people in Post Falls. There must be 8 or 9 of them installed in the past couple of years. Everyone, including me loves the lift. It's too small for a large heavy pick up, so you would want the 9000 which is wider between the posts than the 8000. But for a 3,600 pound car, the 8,000 is perfect. Not only can you do the work on the underside of the car...but power buffing the sides of the car are a blast now...do them at standing height - no more squatting...no more bending over.
'65 Coronet 500
Re: Car lift for your shop [Re: ScottSmith_Harms] #2262681
03/03/17 03:09 PM
03/03/17 03:09 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Originally Posted By ScottSmith_Harms
Well, the lifts are in! I went with a local vendor, CEM Lifts in Post Falls Idaho. Very good service and fair pricing. I did plenty of homework and these two filled the bill for my needs. The 4 post is a Direct Pro Park 8 PLUS LONG 9,000lb ALI certified portable and will be used primarily for storage, the 2 post is a TLT210-A 10,000 Launch Tech and is also ALI certified. It could have been setup as either Asymmetrical or Symmetrical and I went with Symmetrical to give it more versatility.
Now you have one of each and a huge space to work in...I am jealous smile
I have two bays and right now they are both jammed with other peoples stuff....the junk expands to fill the available space.... I need a 4 post just to park my Ramcharger above the other stuff...
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Car lift for your shop [Re: Polarapete] #2262714
03/03/17 03:53 PM
03/03/17 03:53 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I built my shop with the intent of installing a hoist (relative to thickness of slab, height, many other considerations) and finally installed it a few years back. It is a 9,000 capacity Bend Pak that I got second hand. It seems every 2nd or 3rd job requires the wheels to be taken off. 2 post makes the most sense for me and the type of stuff I end up doing. There is enough room for a second hoist in there, if need be. If you can get one, do it...you will not regret it, and it will probably end up being the tool you use most often.
Rich H.
Esse Quam Videri
Re: Car lift for your shop [Re: bobs69] #2263520
03/05/17 02:07 AM
03/05/17 02:07 AM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By bobs69
What lift do you have in your shop? 2 post 4 post? Do you like it or would you change it if you could? We are thinking of getting a 4 post or drive on lift with jack tray and drip trays. Will only be used for our race cars. Have any thoughts any plus or minus. Thanks
Mine
Fastest 300
Re: Car lift for your shop [Re: bobs69] #2263523
03/05/17 02:13 AM
03/05/17 02:13 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Like the lift, LOVE the car! up
Re: Car lift for your shop [Re: bobs69] #2271887
03/18/17 05:59 PM
03/18/17 05:59 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Those who went with the Pro Park, can I ask why? I was comparing it to the Bendpak HD-9XW. The free stuff DP includes as priced is about the same as adding those items to the Bendpak. Sort of a wash on pricing. DP looks nicer; BP seems better engineered. I'm sure either will do the job for me. And Crizilla - Love that ride!!!
And some measurement shows I'll need to swap out my door opener for the Liftmaster jackshaft unit. Barracuda on a lift will not have room for the Hellcat underneath. 12.5ft ceiling but the opener low point is 30 inches down. Another $400 out the window.
Re: Car lift for your shop [Re: bobs69] #2272972
03/20/17 01:51 PM
03/20/17 01:51 PM
K
Kiddart Offline
Kiddart  Offline
K
Vert,
go to this sight, this took about 30 minutes per side and the door works just fine. I did add 1 and a half turns to my Spring tension. I put a 4 post from(Best Buy Auto Equipment).
http://www.garagejournal.com/forum/showthread.php?t=236236
This is how to alter your track without getting a new door or opener
Thank you
Kiddart
Re: Car lift for your shop [Re: Kiddart] #2278736
03/30/17 08:30 AM
03/30/17 08:30 AM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
I like this. How long has it been since you did this? Any issues?
Re: Car lift for your shop [Re: bobs69] #2278940
03/30/17 03:36 PM
03/30/17 03:36 PM
K
Kiddart Offline
Kiddart  Offline
K
been since end of February, had the door open and closed 4 or 5 times over the weekend and no issues. I went to FJ garage doors in Chesterfield Twp. Mi. bought two sections of track(5 foot each) and some fasteners for under $30. The only thing you need to make sure is both sides are cut at the same point at the same angle to keep tracks even all around.
Thank you
Kiddart
Page 4 of 4 1 2 3 4
