94 dakota v6 to 5.9 #2262420
03/03/17 12:43 AM
03/03/17 12:43 AM
ky.
K
kenworth_goose Offline OP
K
ky.
Okay, I miss my v8 Dakota. So I've decided to do a 5.9 swap. It's pretty straight forward but I need to know what do with the 2 extra injectors I need wired in. Anyone give me some advice? I'll switch the PCM to a Ram or Van.
Re: 94 dakota v6 to 5.9 [Re: kenworth_goose] #2262724
03/03/17 04:18 PM
03/03/17 04:18 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I would just grab a 94 318 dakota engine wiring harness with the same trans and be done, it is not hard at all to swap that harness plus you won't have to lengthen everything to reach the front sensors like engine coolant temps and alternator fields...
Re: 94 dakota v6 to 5.9 [Re: kenworth_goose] #2262747
03/03/17 05:18 PM
03/03/17 05:18 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You really only need to add 2 injector driver wires to your existing harness for cylinders 7&8. The other wire is ASD power to the injectors is common to all of them. Just splice into the existing harness. Easy as pie. Use a 96 & up weighted 5.9 flexplate so no converter change is necessary. Just have to file one bolt hole a little to get the offset lug to bolt up. Trim your fan shroud and shorten your radiator hoses and everything else should fall together. Motor mounts are the same as well.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 94 dakota v6 to 5.9 [Re: kenworth_goose] #2262937
03/03/17 11:12 PM
03/03/17 11:12 PM
ky.
K
K
ky.
The engine I have is an 01 and has the flex plate on it. I'm pulling the engine apart partially this weekend to see if everything is good and Maybe shoot for the swap next weekend. Need to know what wires to splice into if you could let me know. AS far I can tell I just need to wire up the injectors and swap the computer.
Re: 94 dakota v6 to 5.9 [Re: kenworth_goose] #2263317
03/04/17 04:40 PM
03/04/17 04:40 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The injectors from the 01 will not plug into any of the v6 injector plugs on your truck. You need to find 92-99 V8 injectors, the yellow ford ones are even better. All of your other sensors need to be swapped from the v6 as they changed most of them between those years, also your valve cover filler and breather holes are probably in the wrong places, they jumped around over the years and aplications. Is you donor engine from a dakota, durango or van? If it is from a ram it will need an oil pan and pickup tube swap (you can use the V6 pickup tube but not the pan).
Re: 94 dakota v6 to 5.9 [Re: HotRodDave] #2263390
03/04/17 07:39 PM
03/04/17 07:39 PM
ky.
K
K
ky.
The engine is from An 01 Dakota
Re: 94 dakota v6 to 5.9 [Re: kenworth_goose] #2263400
03/04/17 08:16 PM
03/04/17 08:16 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Then your pan will work, your injectors will not (without adapters or cutting and splicing all the plugs on it).
Re: 94 dakota v6 to 5.9 [Re: kenworth_goose] #2263786
03/05/17 04:36 PM
03/05/17 04:36 PM
ky.
K
K
ky.
I have a set of injectors that I can use. Hopefully I'll get everything in line for the swap soon. Thanks for the info.
Re: 94 dakota v6 to 5.9 [Re: kenworth_goose] #2264045
03/05/17 11:37 PM
03/05/17 11:37 PM
ky.
K
K
ky.
I torn the engine down and was just going to do a few things to it but the bearings look terrible. Crank looks great but now it's going to get rebuilt. That's going to slow some things down. Looks like it was starving for oil. Screen was partially blocked. People should learn to change the oil once in a while.
