Re: 92 Cruise control into older truck
[Re: lunacy]
#2262942
03/03/17 11:15 PM
03/03/17 11:15 PM
Posts: 2,921 Calgary, Alberta Canada
a12rag
That wasn't primitive . . . that was factory for mopar !!! Way easy to swap into virtually any rig, so long as you get speedo cable to the transducer, and then out of transducer to speedo head. Wiring is simple, you need to get the brake switch from a car with this, as it has another contact in it for the cruise control. Other issue would be the bracket to hold the cable from the cruise control, and the "lost motion" link that fit onto the carburetor . . . . but you could probably figure all that out easier than the "electronics" . . . .
You might find everything you need on a 5th avenue . . . other than the speedo head cable that is . . . The cruise had it's own wire harness that you can take without cutting anything . . . again, get the brake switch, take the cable from the tranny to the transducer, and perhaps the transducer to speedo head . . . and everything else (switch on column, etc) . . .
[Re: lunacy]
#2262995
03/04/17 12:18 AM
03/04/17 12:18 AM
Posts: 435 Austin, TX
lunacy
Austin, TX
Here is what I have decided to try. Take the standalone GM electronic cruise control module http://www.ebay.com/itm/like/232254239908?lpid=82&chn=ps&ul_noapp=trueWhich accepts a pulse signal (I think ideally its 2000 pulses per mile or 4000 ppm with the amplifier) and hook it up to the speedometer output on my transmission controller. The controller can adjust the ratio of pulses coming from the VSS so I should be able to tune it until the accelerate switch gets me approximately +1 mph, etc. This is all in theory, but its what I am going to try as it doesn't add another adapter to the mix nor does it mean using the factory ECM and the added sensors and wiring that takes. If that doesn't work I may try getting the factory ECM to work or a cable speedo to an adapter with VSS for the controller. Now, I will update this when I try it, probably a month or two. Posts where someone comes up with something and never replies back to say it works or not are the worst thing ever on a message board, in researching this on the internet I came across several such dead ends.
