I know, whatever someone is willing to pay, but I have been thinking of selling my '71 Charger 500, or at least the 500 stroker engine.
This is my yellow steet/strip '71 Charger 500 (model), with a 500" B-block stroker engine.
I'm not even sure how much $$$$$ I have in the car, but curious what people are paying?
The engine should make 700+ HP?
This the '71 230 B-block, 4.375"x4.150" 440 source rotating assembly with the older 4340 "I" beam rods and ARP2000 bolts. BCR aluminum main Caps and stud girdle.
Hughes engine Monster CNC ported (about 400 cfm) MW victor heads,
1.6:1 T&D rockers, PAC-1326 springs, PAC Ti retainers, Smith Brothers 3/8"x0.145" wall pushrods, Indy 400 4150 intake, QF 1050cfm 4150 E-85 carb, ect.
The trans is a 727 with Cope max lug modified pump, Billet steel front drum, lightened sun shell, Billet aluminum rear drum, A&A super sprag, Billet oversize front servo kit, Cope Reverse manual valve body, Billet steel 4-pinion gear, Custom 9" Ultimate Converter built torque converter, ect...
Rear axle is the Strange S-60 4.10 gear with spool.
Mark Williams CrMoly driveshaft, 1350 u-joints, ect...
Car body is mostly straight (no dents) has a few paint chips and small dings on the sides, but the trunk lid has hail damage (hail crashed through car trailer roof vent.)
Lower rear quarters were repaired due to rust around 1990? The rest of the car is very solid, but has some body filler under the paint which still looks good.
At work now, So I don't have pictures to post.
