yes they use a body sealer. I wire wheeled/sand/grind it all out then did the repair/and resealed with paintable body seam sealer/primer/paint/clear
did the whole drip rail acroos the front down around door rail.
even did the thin parting line across the back of cab/roof line. looking back I wish I had welded up the cargo light hole. I going to have to use some type of sealer on my yellow truck.
when I sprayed the 85/91 cab, I did the area then installed the cargo light while wet. then kept brush filling it around the seal/cab and kinda glued it in with bed liner. no leaks on it as far as I can tell.
I will weld in a piece on the next cargo light cab I repair.
IIRC, another leaky spot is on the cowl top corner. have to remove fender to see where the metal is folded/rounded in to the cowl corner. they will crack and have a seam that can leak in that area also.
