Factory Cassete Player #2247332
02/04/17 08:07 PM
02/04/17 08:07 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
http://r.ebay.com/BYibYT I Never saw this bracket before connected to the main bracket & running across the top of the player,later 74 style anti theft or vibration ?
Re: Factory Cassete Player [Re: 71GTX471] #2247365
02/04/17 09:10 PM
02/04/17 09:10 PM
I would guess vibration.
Re: Factory Cassete Player [Re: 71GTX471] #2259324
02/25/17 04:43 PM
02/25/17 04:43 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
Yes, that is the anti-theft bracket. The interesting thing is the factory riveted it to the base bracket using the same rosette rivets used for the dash VIN tag.
Re: Factory Cassete Player [Re: charger440sixpak] #2259406
02/25/17 07:09 PM
02/25/17 07:09 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I have several with the anti-theft bracket.
All have normal rivets, interestingly some riveted from the front, some riveted from the back
Re: Factory Cassete Player [Re: mccannix] #2259459
02/25/17 09:14 PM
02/25/17 09:14 PM
Horsham, Pa.
Finoke Online content
Finoke  Online Content
Horsham, Pa.
Not to hijack the thread but does anybody have a source that repairs the cassette player? Mine doesn't work and I'm assuming that most don't.
Re: Factory Cassete Player [Re: 71GTX471] #2259479
02/25/17 09:46 PM
02/25/17 09:46 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
The brackets mccannix is showing are on the sides of the main bracket are they part of the bracket that passes over the top as in the first ebag auction,now I see the same seller has another one listed with that bracket,any more info on these brackets IE later addition, I've never seen them before & now there's 2 showing up & both from the same guy.
http://r.ebay.com/qAlLZe
Re: Factory Cassete Player [Re: mccannix] #2260427
02/27/17 12:58 PM
02/27/17 12:58 PM
SF Bay Area, CA
SF Bay Area, CA
It's the rivet attaching the anti-theft bracket to which I was referring.
Re: Factory Cassete Player [Re: 71GTX471] #2260773
02/27/17 11:22 PM
02/27/17 11:22 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
I see its really 3 brackets making up the antitheft bracket,cant believe Iv never seen this before.I wonder if it shows up in the later 74 parts catalog.
Re: Factory Cassete Player [Re: 71GTX471] #2260981
02/28/17 12:29 PM
02/28/17 12:29 PM
SF Bay Area, CA
SF Bay Area, CA
The early 70's models used two 1-87-1 3501522 Torque Screws, on on each side; they are listed in the 70-71, 72 & 73 parts manuals. The head was designed to snap off after installation. They're a real PITA to remove.
The torque screws aren't listed in the 74 parts manual. At some point during these years the method for theft deterrent changed to the bracket and rivet design reflected in the previous posts.
