Anybody wanna school me on manual valve bodies?
#2259314
02/25/17 04:26 PM
02/25/17 04:26 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
I searched for threads but didn't find much. After frying the clutches due to kickdown non-adjustment, I'm considering switching to manual. Car is street-only, Barracuda, 528 hemi.
Re: Anybody wanna school me on manual vale bodies?
[Re: sam64]
#2259351
02/25/17 05:50 PM
02/25/17 05:50 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Years ago I built a 727 with a RMVB and used it in my street toy, '68 Coronet that evolved into a race only bracket car. It seems to me that I used the instructions in a B&M kit to modify the transmission, but that was 30+ years ago, so I can't be certain.
At the same time I was seeing the rise in the fortunes of Al Young. He has been a fixture of Northwest Drag Racing for years, and he still goes out to play. His Dodge Challenger sponsored by Bardahl was donated to the Museum of History and Industry in Seattle and is frequently on display. His transmission was built by Pat Blais with one of Pat's valve bodies. We all thought that he was shifting for himself, but he was actually leaving it in drive and was winning automatically!! Pat had fine tuned the governor weights to shift at the best RPM for the power band of the motor. Al was eventually able to run in the eights that way. He and Pat came to a meeting of the Seattle Chapter of Mopars Unlimited and the truth came out in their presentation. So maybe you really don't need a manual valve body after all? Just sayin'
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Vert]
#2259480
02/25/17 09:47 PM
02/25/17 09:47 PM
Posts: 20,176 Park Forest, IL
slantzilla
Park Forest, IL
Racing a 727 in drive on a car with any horsepower is a good way to blow it up.
[Re: Vert]
#2259552
02/26/17 12:13 AM
02/26/17 12:13 AM
Posts: 3,921 Richmond, Indiana
19swinger70
Richmond, Indiana
I have a reverse manual vb in my 340 dart. Street driven since 2001 and love it.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: Vert]
#2259588
02/26/17 01:05 AM
02/26/17 01:05 AM
Posts: 12,072 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What RPM do you shift your Hemi at?
I have ran both full auto and manual valve bodies on the street and on the strip. The full autos did a good job behind my wedges that shifted under 6,000 or so.
But on my Hemis that want to pull well over 6,000rpm, getting our Torqueflites to auto shift up there is a real challenge. And then there is the 1-2 and 2-3 split that will also have to be dealt with.
But then for a street car, a manual valve body takes some attention while driving around town to keep from beating the drive train out. You can soften the shifts up a little bit, but manual valve bodies are usually rather harsh shifting on the street.
Either one can be made to work for you.
Master, again and still
[Re: sam64]
#2259631
02/26/17 02:23 AM
02/26/17 02:23 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
you will get tired of shifting. Mine is a RMVB... with PUSHBUTTONS. It's fun, actually.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: stumpy]
#2259672
02/26/17 09:58 AM
02/26/17 09:58 AM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
It would be a lot easier to fix the kickdown(throttle pressure) linkage. But on my Hemis that want to pull well over 6,000rpm, getting our Torqueflites to auto shift up there is a real challenge. And then there is the 1-2 and 2-3 split that will also have to be dealt with.
Full manual verses automatic is a personal choice. If I'm going to shift, it will only be a manual transmission. I got my auto to auto shift at 6500, but I was in the governor once, and the VB twice.
[Re: A727Tflite]
#2259775
02/26/17 01:40 PM
02/26/17 01:40 PM
slantzilla
Park Forest, IL
Interested in your theory on why the trans would blow up if raced in drive. When you stand on it in drive the low band is not applied. IF you spin the tires, let off, and get back on it you can roll the sprag and overspeed the front drum. Bad things will come your way if that happens. You can do the same thing with a RMVB that does not have low band apply. A RMVB on the street is not that bad. If your motor has some nuts you can start off in second at stop lights, and if you have a good converter even third.
[Re: slantzilla]
#2259978
02/26/17 05:32 PM
02/26/17 05:32 PM
Posts: 3,075 Michigan
A727Tflite
Interested in your theory on why the trans would blow up if raced in drive. When you stand on it in drive the low band is not applied. IF you spin the tires, let off, and get back on it you can roll the sprag and overspeed the front drum. Bad things will come your way if that happens. You can do the same thing with a RMVB that does not have low band apply. A RMVB on the street is not that bad. If your motor has some nuts you can start off in second at stop lights, and if you have a good converter even third. . Nonsense. If left in drive and the tires spun badly the trans would likely shift to 2nd by itself - and probably faster than you could manually if you weren't prepared for that spin. And also likely upshift before you could lift your right foot.
[Re: Vert]
#2259988
02/26/17 05:53 PM
02/26/17 05:53 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
My stroker makes about 630lbft... coming off a light, I can start in 3rd as long as I'm easy on it. Most times around town, no need to shift.
