brake booster check valve #2259306
02/25/17 04:05 PM
02/25/17 04:05 PM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
How do you test it?
Re: brake booster check valve [Re: FC7 cuda] #2259489
02/25/17 10:18 PM
02/25/17 10:18 PM
other than if it holds vacuum and properly activates the brake I ain't sure.
Re: brake booster check valve [Re: FC7 cuda] #2259685
02/26/17 11:11 AM
02/26/17 11:11 AM
btomasko Offline
btomasko  Offline
If you take the hose off the intake manifold and blow into it,you should not be able to push the air thru,then if you try to suck the air out of the hose you should be able to this freely.If the air goes thru when you blow into it you will have a leak.
Re: brake booster check valve [Re: FC7 cuda] #2259740
02/26/17 12:42 PM
02/26/17 12:42 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Ram Man has new ones if needed.
twocents
