Nice Mopar from Montreal #225837
02/15/09 04:13 PM
02/15/09 04:13 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
A nice Moparts member from Montreal emailed me today, he said he doesn't speak much English and asked if I'd post some pics of his Hot Rod. This thing is cool, 4320 pound Polara, 505ci with 725HP, 10.77 at 126.3.
Re: Nice Mopar from Montreal [Re: ProSport] #225838
02/15/09 04:13 PM
02/15/09 04:13 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
2
Re: Nice Mopar from Montreal [Re: ProSport] #225839
02/15/09 04:14 PM
02/15/09 04:14 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
3
Re: Nice Mopar from Montreal [Re: ProSport] #225840
02/15/09 04:14 PM
02/15/09 04:14 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Re: Nice Mopar from Montreal [Re: ProSport] #225841
02/15/09 04:14 PM
02/15/09 04:14 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Re: Nice Mopar from Montreal [Re: ProSport] #225842
02/15/09 07:07 PM
02/15/09 07:07 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
I commend him on how super clean and stock looking it is. And to be able to run those times.. Talk about ultimate sleeper. I wonder how it sounds. Could you imagine sitting next to that at a stop light and having NO CLUE what it's capable of.. REAL NICE job...
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Nice Mopar from Montreal [Re: ProSport] #225843
02/15/09 07:36 PM
02/15/09 07:36 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Very unique
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Nice Mopar from Montreal [Re: ProSport] #225844
02/15/09 08:14 PM
02/15/09 08:14 PM
Central NC
gch Online content
gch  Online Content
Central NC
Pretty freakin awesome!The guys over at www.cbodydrydock.com would love this one.I love 67-68 Polara's.The A body scoops on the hood look pretty good on there.
Re: Nice Mopar from Montreal [Re: gch] #225845
02/17/09 07:45 PM
02/17/09 07:45 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Here's some good info he wanted me to ad to it, copied from his email:
Block 440 1972 .30 over with studs caps stock
4.250 stroke
6.800 eagle rod 2.20 ratio
Diamond pistons 4.350 bore 11.7 comp.
Cam .590 mopar install 104 timing 32
Heads 346 casting 78 cc 2.20 int. 1.81 exh. full porters 285 cfm @ .600 lifts
Iron rockers 1.6
Intake street dom. spacer 3/4 open plenum work match port
Carb 800 holley double pumps jet 74 87
Carter pump fuel 120 gallons 3/8 line
headers 1 3/4 pipe 3'' tail pipe 3'' muffler dynomax ultraflow
9" 4700 flash stall conv. 2.2 litres 4 cyl. case modified piece ATI by Autopital trans.
Diff 8 3/4 gears 3.91 tire 30" 9" 15" goodyear drag rim metal 7"
60 foots 1.62
ET 11.50 at 118 shift 5400 rpm trap 5700 rpm
Change to the heads indy easy 75cc standard port, ported 315 @.600 lifts
Intake m1 spacer 3/4" plenum work ported runner match port
Carb 1000 cfm vac. jet 86 88 timing 36
dana 60 mooser gears 4.30 spool rim alum. 10" slide link bar spring B body
Stall flash 4800
Muffler 3"borla XR1 no tail pipe
60 foots 1.57
ET 11.18 at 120.7 shift 6100 rpm trap 6300 rpm
Change to the heads victor 440 standard port ,ported 346 cfm@ 700 lifts 2 angles valves chambre combustion work
Port csa 2.40 X 1.25
Intake m1 stage 5 race port 331 casting 4150 plenum work match port
Carb jet 88 90 pump fuel elect. aeromotive
Cam isky roller mec. .672 lifts 272 dur.@ 0.50 install 104 timing 38
Roller rockers 1.6 H.S pushrod manton 3/8 .95 wall
Headers dougs 2" 3 1/2 pipe 3 1/2 muffler 3 1/2 dynomax ultraflow no tail pipe sounds greats but not legal street montreal
Stall flash 5000
60 foots 1.50
ET 10.77 at 126.3 shift 6500 rpm trap 6700 rpm
