steering problem #2258128
02/23/17 11:37 AM
02/23/17 11:37 AM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
I just replace my power steering gear box in a 68 Fury with a new Cardone. Now, on taking a 90 degree corner, when I let go of the steering wheel, it does not return to near center as it did before. The wheel (and car) stays in a hard (left or right) turn.
Re: steering problem [Re: TrueTripleX] #2258155
02/23/17 12:39 PM
02/23/17 12:39 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Is the valve properly centered? (Does the steering wheel have any tendency to turn itself, especially with the front wheels off the ground)?
Re: steering problem [Re: TrueTripleX] #2258190
02/23/17 01:55 PM
02/23/17 01:55 PM
jack the front wheels off of the ground. center the wheels. start/idle it. wheels should not move/pull to one side.
Re: steering problem [Re: TrueTripleX] #2258201
02/23/17 02:17 PM
02/23/17 02:17 PM
Andrewh Offline
Andrewh  Offline
it is unlikely that the valve is centered. you will need to do as robert says and try it with the front wheels in the air, and then adjust as needed.
don't stick your arm through the steering wheel when starting.
Re: steering problem [Re: TrueTripleX] #2258213
02/23/17 02:55 PM
02/23/17 02:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It doesn't sound like it pulls to either side just doesn't return. That would lead me to believe the box is adjusted too tight. The nut on the body with the screw in the center is the adjustment for that. Loosen the nut and give the back the screw out a little at a time until the steering returns to center like you want.
Re: steering problem [Re: TrueTripleX] #2258235
02/23/17 03:46 PM
02/23/17 03:46 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I had this on a number of different Mopars. The steering wheel was too tight to the column. I pulled the steering wheel and tightened it only enough to take out any play to the column. It is a jamb nut so no worries about it coming loose.
Re: steering problem [Re: TrueTripleX] #2258241
02/23/17 04:01 PM
02/23/17 04:01 PM
Andrewh Offline
Andrewh  Offline
I suppose it could be, but I have had the valve adjusted wrong as well where it won't allow return.
It could also be alignment etc..
but if all he changed was the box, then that is where I would start.
