Stroker needs to be quieter
#2258025
02/23/17 01:20 AM
02/23/17 01:20 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Aussie Valiant with 547ci RB, we have Headman fenderwells with our own 3.5" system, X pipe and Hooker Aero's, this thing is LOUD !! We need to drive it on the street a little more so will be doing tail pipes but would like to know what second pair of mufflers or bullets we should go for. Already have the 3.5" pipe and bends and there is no gas tank to worry about as it runs a cell. Maybe another set of Aero's ?? Cheers
1963 Plymouth Max Wedge 1971 Barracuda
Re: Stroker needs to be quieter
[Re: ozymaxwedge]
#2258042
02/23/17 01:49 AM
02/23/17 01:49 AM
RapidRobert
put a pair of the longest glasspacks you have room for alongside the rear leaf springs. be sure & get ones that do not neck down where the ends are welded to the main case & if the louvers are punched outward there is less restriction but alot less muffling. I've used the cheapie "cherry bombs" with good surprisingly results & they do not neckdown & have outward punched louvers. EDIT you might also Google reducing sound in an auto motive application with a helmholtz resonator. iirc it is a long horizontle ex pipe section about a foot an a half long welded on each pipe bend as it goes over the axle and capped on the end & the sound waves cancel each other out to some extent. Too high tech for me but reportedly it works.
[Re: ozymaxwedge]
#2258095
02/23/17 05:25 AM
02/23/17 05:25 AM
Posts: 10,176 A Red State
SNK-EYZ
A Red State
You might be surprised how much even having tailpipes could help. With the dumping in front of the rear axle it will resonate under the body.
Having tailpipes and some sort of muffler behind the rear axle will quiet it down a lot.
[Re: ozymaxwedge]
#2258189
02/23/17 01:55 PM
02/23/17 01:55 PM
Posts: 3,289 West Coast, USA
jbc426
West Coast, USA
I had Hooker Aero Chambers on my 408" Magnum with full 3" TTI exhaust w/ H-pipe. They were too loud, so I swapped in a set of Dynomax mufflers and it took out a lot of the deep sound waves. Much nicer now.
I have the same 3" full TTI exhaust on my 493" RB with x-pipe and Hooker Aero chambers. That car is quiet with the tips out the back valence.
Go figure.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: ozymaxwedge]
#2258508
02/24/17 02:18 AM
02/24/17 02:18 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Does that car have brakes?? Why do I not see a master cylinder?
[Re: boydsdodge]
#2260280
02/27/17 02:06 AM
02/27/17 02:06 AM
ozymaxwedge
Australia
Thats a wild ride, did they build that body in two door? Yes they did, much the same as your Darts.
